| Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE |
| Best place to buy Rubicon Express! Don't Fear the Jeeper! | Insane Rough Country Deals Call for more Info!!! so insan | Barnes 4WD Universal 4 Link Kit |
| Jeep Registry | Register | Blogs | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Mmmmm Jeeps
Will a bad VSS prevent starting?
US Army combat vet Armed Forces Jeeps Member #125 Red Jeep Club Member #251 In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club Click here for 2.5L AX5 to AX15 swap |
#2 |
you sure you didnt get 12 33 and 55 ??
1989 Wrangler Black Bone Stock 2.5l 5spd /l , [____], |---L--[]lllllll[]- ()_) ()_)==O=)_) |
#3 |
Mmmmm Jeeps
Well, I did get 55 after 15. 55 is end of codes right?
#4 |
Missing VSS shouldn't cause any problems starting.. I'd say cam sensor
#5 |
Mmmmm Jeeps
Would a cam sensor failure trip a code?
#6 |
cam sensor wont trip a code always.
#7 |
Mmmmm Jeeps
So, I pulled the crank sensor and tested it for resistance.
It appears that it is open. I'm going to try a new one of those. Can someone give me more info on the CAM sensor?
#8 |
90% of the time it will be your crank position sensor OR wiring...then I would move onto the PMC/computer.
1. Check the 8-volt power supply to the Cam Angle Sensor (CMP) and Crank Angle Sensor (CKP). 2. Unplug them (cam and crank) and the Vehicle Speed Sensor (VSS) and then turn the key on. 3. If 8 volts is now present, start plugging each of the sensors in again, to see which one is shorted out. Potential Causes: Crank Angle Sensor (CKP) Cam Angle Sensor (CMP) Vehicle Speed Sensor (VSS) Powertrain Control Module (PCM) Wiring A PCM shut-down, due to a short to ground on the 8 volt power supply. The sensor may not come back to life, after removing the short, unless the key is cycled off and then on. Also, The Automatic Shut Down (ASD) relay is powered up when the Powertrain Control Module (PCM) sees the signal from the CKP sensor toggling. Another check: 1. Check the 8-volt power supply to the Camshaft Position (CMP) sensor and Crankshaft Position (CKP) sensor. 2. If OK, check the Grey/Black wire at the CKP sensor for a 0-5 volt square wave signal when cranking. 3. If not a 0-5 volt square wave signal, the CKP sensor is faulty. ![]()
#9 |
Resident Audio Guru
VSS will only trigger your CEL -- I've been driving without it for a while.
-Matt White '94 YJ - *Front Wheel Drive* Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, 31x10.5r15, American Racing Atlas Rims, Addco Front Swaybar My really slow YJ build For trade: '94 Family roll bar. XJ + YJ Drivetrain parts for sale. |
#10 |
Mmmmm Jeeps
Well, I can't figure out the 8 volt thing...could be my crappy Harbor Freight multi meter.
I don't get why the CKS, or CMS aren't showing a code if they are bad.
#11 |
If the cam goes the engine will turn but you wont get spark, but you will have power to the coil, asd, fuel pump, etc. which is the indication of the bad crank sensor. Vss can stop the vehicle from starting on a short. It will take down refrence voltage.
#12 |
Mmmmm Jeeps
Okay, I think I figured out the voltage thing.
I've got 9 volts at the VSS, CKS, and CMS plugs. I tried a brand new CKS, and no start. Sooo, I'm back at square 1. I'm familiar with the 4.0 motors, but after cranking a few seconds, it smells of gas almost like it's flooded. No leaks anywhere. Also, it won't start on starting fluid. I pulled the codes again today, and it's still 12, 33, and 15.
#13 |
Mmmmm Jeeps
Well, I replaced the VSS just now, and still no start.
I didn't think the VSS would make any difference, but it was bad and we wanted a speedo again when it runs again. So, the only other thing is the ECU?
#14 |
Mmmmm Jeeps
Well, as I do more reading on failing ECU's, it sounds like I shouldn't be getting spark and or fuel pump priming. Is this true? If so, I have both spark and fuel.
What is the ECU doing to keep it from starting?
#15 |
Mmmmm Jeeps
Just for fun I just tried the NEW CKS with the NEW VSS, and still no go.
At least I can take that back and get my $60 refund.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| can anything prevent rust? | MC_NickP | TJ Technical Forum | 5 | 01-01-2009 08:01 PM |
| soon to be problem, how to prevent? | trw | YJ Technical Forum | 7 | 08-03-2007 07:58 PM |
| AC to prevent SAS | austineo | TJ Technical Forum | 3 | 03-30-2006 11:10 AM |
| how do i prevent this? | paroxysym | TJ Technical Forum | 4 | 01-23-2006 03:09 PM |
| Anybody use this to prevent rust? | Butters98TJ | TJ Technical Forum | 0 | 01-01-2005 09:41 PM |
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
