Will a AMC 318 fit onto TF999??? - JeepForum.com
post #1 of 5 Old 04-11-2006, 03:27 PM Thread Starter
Kimoscout
Talking with one of the guys and he suggested trying a 318 from a Cherokee to bolt onto my 87YJ with a TF999 auto tranny. Any suggestions or info.
Kimoscout is offline
post #2 of 5 Old 04-11-2006, 08:01 PM
Cobra Jeep
NO. The 318 (5.2L) used in the ZJ's are not AMC engines, they are mopar (dodge) engines and will not bolt up to your YJ's transmission. If you want a V8 that will bolt up to your trans (that I am assumeing was bolted to a 258) you will need to find a AMC 360 from a 91 or older Grand WAGONEER. Those are AMC engines and share the same trans bolt pattern as the 258. Any V8's in jeeps past 91 will be a mopar engine and will not work. Yes some of the later ZJ's came with 360's (5.9L) but they are also mopar engines, and share NOTHING with the AMC 360's other than the displacement. Hope this helps.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #3 of 5 Old 04-11-2006, 09:34 PM Thread Starter
Kimoscout
Thanks for the input. After some toolin around on the net, I think I came to the same conclusion that the 318 wouldn't bolt up in place of my 258. I was considering a 304, but they have been reputed to be lacking in power. The 360 sounds nice, how about motor mounts?
post #4 of 5 Old 04-12-2006, 07:13 PM
Cobra Jeep
As for motor mounts you will have to cut your old ones off the frame and make some new ones. I think advance adapters has some pre made motor mounts to put a AMC V8 into a YJ. Just one thing to remember about AMC V8's. The flywheels and flex plates are NOT interchangeable. They are all balanced diffrently, so if you were to bolt a flex plate from a 304 on to a 360 (or vice versa) you would be sending it to a early grave. Whatever AMC engine you choose make sure you get the right flywheel. Also the same goes for the harmonic balancers, if the engine you get happens to be missing it, make sure you get the right one.
post #5 of 5 Old 04-13-2006, 09:16 AM
jeepnguns
jeepnguns's Avatar
I do not know if it is true or not but I have heard the AMC 360 and 304 will bolt into the 258 engine mounts.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline
CJ vs YJ TF999 VACJ5 YJ Wrangler Technical Forum 23 03-18-2010 09:49 PM
Visually tell TF999 or AW4 mmmkay325 YJ Wrangler Technical Forum 9 04-06-2009 06:16 AM
chevy 350 behind TF999 JJ Jeep YJ Wrangler Technical Forum 0 05-16-2008 07:02 PM
Tf999 COJAM YJ Wrangler Technical Forum 0 11-16-2005 12:30 PM
Going from AX to TF999 what am I in for? BackRoadJPin YJ Wrangler Technical Forum 7 08-22-2005 11:47 AM
