Will .06" SP gap cause harm? - JeepForum.com
post #1 of 2 Old 02-07-2002, 09:33 PM Thread Starter
Matt Bodnar
ok,..I got the 4.2 with the carb,..and I got to the point that I I would loose speed and power in 5th. then it would flood cause it had no power .
So I got a HEI coil from an 1985 GM 2.5l motor,(that I had laying around)..and replaced the tin can one.
Then the gapping 4 that motor sayz .06", so I gapped mine to that also.
I had the TFI base and large cap but switched to the stocker again.
I test drove it and it starts better and runs better too,..with more acceleration .
I am wondering if the increaced gap will harm the motor?
it should just lower performance,..right?
but it didn't so will it be ok untill I get the TFI coil and switch it all over?
thanks
Matt
Matt Bodnar is offline
post #2 of 2 Old 02-08-2002, 01:08 AM
jeffy
jeffy's Avatar
I don't see a problem. If the engine runs fine then go with it. Typically when you fo things like a MSD or Jacobs you can widen the gap. Basically adding HEI is the same thing. If the gap is too wide then it won't arc and fire the cylinder.
*** www.4BangerJP.com ***
jeffy is offline
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
Will upgrading my front disc brakes do more harm then good? usurp TJ Wrangler Technical Forum 16 12-05-2007 01:38 PM
would this cause any harm. seafoam related fatboyq YJ Wrangler Technical Forum 3 05-08-2006 09:58 AM
any harm being done? paroxysym TJ Wrangler Technical Forum 15 12-18-2005 05:09 PM
running a smaller spare om fromt - no harm done? Toploader YJ Wrangler Technical Forum 5 03-20-2003 06:59 PM
