Wierd Turn Signal and Brake light issue,,,, - JeepForum.com
post #1 of 8 Old 04-09-2013, 08:58 PM Thread Starter
Robob69
OK this is strange...
Tonight I am driving and I am loving my LED Tail/Brake light Upgrade when I look back at a stop sign and I notice that my Left Brake light is out...
So. I get to the next stop sign where again I am turning right and I see that my Left Stop Light is on until I turn my Right Turn Signal on... Now I turn my Left signal on and the Right Brake light stays on...
Do I have a Turn Signal Switch gone out?
This may have been going on forever and I never knew because the freaking OEM lights were so dim you had to use a flashlight to see if they were working,,
Robob69 is offline
post #2 of 8 Old 04-10-2013, 10:04 PM Thread Starter
Robob69
Anybody have a clue?
Robob69 is offline
post #3 of 8 Old 04-10-2013, 10:22 PM
GrantYJ
Do you have enough resistance to trip your blinker relay? If you don't, it'll do what you're describing. If you do have enough resistance, it's most likely a ground issue.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #4 of 8 Old 04-10-2013, 11:09 PM
dhunt09
I'm having a similar issue where my left brake light will only work if the left turn signal has been engaged and will work normally until the right signal is used.
I'm sure they're related issues so I'll be following along!
dhunt09 is offline
post #5 of 8 Old 04-11-2013, 09:01 AM Thread Starter
Robob69
I replaced the flasher with an electronic flasher. The right side works perfect. Only the left side will do this..
Robob69 is offline
post #6 of 8 Old 04-11-2013, 10:24 AM
BretB
^^This is a very common cause written about.
The variance in your symptoms is odd, but I want to add my .02 on signal experience and LEDs:
Before I added LED's, I had issue of using my turn signal, it would remain solidly lit, and turned out I just had a front bulb burned out - so check all your bulbs first.
I will add, though, that I never addressed the resistance issue and only issue is a split second delay in the turn signal activating now... guess I lucked out.
1989 YJ
1998 Harley Davidson Fatboy
2000 TJ (wife's)
2009 Chevy K1500
BretB is offline
post #7 of 8 Old 04-11-2013, 10:30 AM Thread Starter
Robob69
All bulbs are good. Everything is now LED but the front parking/turn signals only bc I have not gotten them in yet. The turn signal works perfect... just that I have no brake light in that side when the right signal is on..... Strange..
Robob69 is offline
post #8 of 8 Old 04-11-2013, 12:54 PM
b_a_mech
Id have to see the wires to be sure but it sounds like either a ground issue or if your lights had two or three wires coming for hook up. If it had two then it is not a dual setup...meaning when you put your turn signal on it flashes only.
If it has three wires it is a dual and when you put the turn signal on it flashes but light stays on just gets brighter for the turn indication....does that make sence?? Its always easier for me to see it to know for sure...I just changed over to LED and had to swap wires around after first power up....
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
