wierd steering issue - JeepForum.com
post #1 of 12 Old 10-20-2006, 01:07 PM Thread Starter
toates89
1989 XJ Cherokee
89 4.2 power steering. the problem is it is harder to steer and doesnt straighten out after turn. its been like this for 3 weeks yesterday it went back to normal today it was hard and i have a squecky belt. i greased all joints belt is tight and power steering pump is pumping fluids
any ideas
could my belt be slipping
toates89 is offline
post #2 of 12 Old 10-20-2006, 08:50 PM Thread Starter
toates89
1989 XJ Cherokee
bump please
toates89 is offline
post #3 of 12 Old 10-20-2006, 09:43 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
any ideas
I'm no expert, but did you check the resevoir to see if the pump is actually pumping?
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #4 of 12 Old 10-21-2006, 08:46 AM Thread Starter
toates89
1989 XJ Cherokee
yea its pumping i took the hose off and ran it and it pumped fluid
toates89 is offline
post #5 of 12 Old 10-21-2006, 08:52 AM
Mr.B
Mr.B's Avatar
Sorry about that. I guess I didn't read your whole post last night. The pump has a relief valve that may be clogged. You could clean that out and put in fresh fluid. That would be the easiest thing to do first.
Ham license:
Everyone is Welcome
Mr.B is offline
post #6 of 12 Old 10-21-2006, 09:49 AM
BigMikey
Perhaps it may be your steering box....like mine
BigMikey is offline
post #7 of 12 Old 10-21-2006, 09:53 PM
jeeepguy
jeeepguy's Avatar
Steering box... replaced mine after I had similar conditions and its been good ever since.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #8 of 12 Old 10-21-2006, 09:57 PM Thread Starter
toates89
1989 XJ Cherokee
but why was it good for 24 hours and then not good the next day and where is this releif valve of which you speak
toates89 is offline
post #9 of 12 Old 10-22-2006, 10:28 AM
Mr.B
Mr.B's Avatar
Like I said before, I'm no expert on the subject. I just installed power steering on my Jeep last week. One of the brochures that came with my pump from Napa, talks about the relief valve. It says that it may get clogged from contamination. The valve looks like it is the part that the pressure hose screws into. It looks like it can be unscrewed from the pump. The picture shows an O ring and a spring inside, so be careful if you pull it out. Maybe someone withsome first hand knowledge will post.
Ham license:
Everyone is Welcome
Mr.B is offline
post #10 of 12 Old 10-22-2006, 10:54 AM Thread Starter
toates89
1989 XJ Cherokee
i will try and google this releif valve
toates89 is offline
post #11 of 12 Old 10-22-2006, 07:25 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
It's duirty fluid more than likely
Take the low pressure side off, place in a bucket and run 3-4 quarts through it with motor running. It'll flush out al the old gung, chunks and stuff.
Refill and bleed, it'll be good as new.
- Ernie
Richmond88yj is offline
post #12 of 12 Old 10-22-2006, 07:33 PM Thread Starter
toates89
1989 XJ Cherokee
i already flushed it and no good
toates89 is offline
wierd stalling issue 97tjtom TJ Wrangler Technical Forum 8 09-24-2012 03:21 AM
wierd steering dezertdude TJ Wrangler Technical Forum 7 04-28-2009 05:39 PM
Wierd electrical/light issue... help! MikeyJ YJ Wrangler Technical Forum 6 03-23-2009 12:04 PM
lift= wierd steering wheel tire issue? brinoff YJ Wrangler Technical Forum 3 03-16-2007 12:34 PM
Wierd Fuse Issue...HELP. blakkbelt YJ Wrangler Technical Forum 1 11-29-2005 05:23 PM
