Wierd Brake Issue . . . - JeepForum.com
post #1 of 7 Old 10-30-2010, 11:09 AM Thread Starter
YJ Newby
I recently changed the front brakes on my '90 YJ and completely bled the lines [Bled into a clear beer bottle until the new, clear fluid I was adding to the master came through]. I never really had tight brakes since then. Now, in the past week or so, there is absolutely no resistance when applying the brakes until the pedal is depressed almost half way. At that point I really have to mash down on them to get good stopping power. The wierder part [is that a word?], is that I do not have brake lights until I have pressed down beyond the "spongy" period and start getting resistance. Am I looking at a new Master Cylinder?
Thanks for your replies . . .
YJ Newby is offline
post #2 of 7 Old 10-30-2010, 01:32 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
I would try bleeding again. Did you change the calipers?? If so, just be sure the bleeder is to the bottom, they can be installed on the wrong sides and if the bleeder is on top, you will never get the air out.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 7 Old 10-30-2010, 03:53 PM
Mark05059
The bleeder goes to the top so the air comes out. Air rises to the top of the master since the brake fluid is heavier then air. You then open the bleeder and push the air at the TOP out.
Bleeder screws to the top
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 7 Old 10-30-2010, 10:51 PM
K4KAS
Already stated above. A left caliper will install on the right side and vise verse. Ensure the caliper is installed with the bleeder screw to the top. They may have given you 2 of the same side caliper.
K4KAS is offline
post #5 of 7 Old 10-31-2010, 08:30 AM
MWT
your master cylinder is bad.
MWT is offline
post #6 of 7 Old 10-31-2010, 08:40 AM
Mark05059
Not always the case. Could be air in the lines as well.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #7 of 7 Old 10-31-2010, 12:05 PM
Old4X
1990 CJ7
Re-set the proportionating valve. Then re-bleed the system, start at back right wheel, end with front left.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
wierd stalling issue 97tjtom TJ Wrangler Technical Forum 8 09-24-2012 03:21 AM
Wierd brake light issue UltimateCC TJ Wrangler Technical Forum 5 04-30-2010 09:43 PM
Wierd electrical/light issue... help! MikeyJ YJ Wrangler Technical Forum 6 03-23-2009 12:04 PM
wierd steering issue toates89 YJ Wrangler Technical Forum 11 10-22-2006 07:33 PM
Wierd Fuse Issue...HELP. blakkbelt YJ Wrangler Technical Forum 1 11-29-2005 05:23 PM
