wide open throttle switch problem - JeepForum.com
post #1 of 9 Old 07-01-2011, 02:00 PM Thread Starter
InEmberClad
Hey guys,
Did some searching, found This thread and followed the steps detailed there. Turns out my wide open throttle switch is broken, and I have scoured the internet high and low trying to see if I can't find a new one, no luck so far...
Says here though that its just a normally open switch which closes the contacts when the throttle is all the way open, I feel like I could just buy a button at radioshack and mount it so that it does the same thing. Does anybody know if there might be any problems with that plan?
InEmberClad is offline
post #2 of 9 Old 07-01-2011, 04:00 PM
ctm
go for it, and add the part # to this thread that you end up using
ctm is offline
post #3 of 9 Old 01-04-2012, 07:41 AM
89WhyJ
Any updates? Did this work? My WOT switch needs replacing and I'm in the same boat.
89WhyJ is online now
post #4 of 9 Old 01-04-2012, 08:52 AM
Que89YJ
Que89YJ is offline
post #5 of 9 Old 01-04-2012, 07:34 PM
89WhyJ
Thanks Que!
post #6 of 9 Old 03-24-2013, 12:14 PM
ShArKtRaInEr
Anyone else know where to find one? The link above no longer stocks it. Much appreciated.
ShArKtRaInEr is offline
post #7 of 9 Old 03-27-2013, 08:20 AM
89WhyJ
Yeah, I couldn't get it from the supplier either. I think I'm going to radio shack and pick up a simple SPDT level switch. In my case, the switch mechanically closes and won't mechanically re-open (like an electronic latch). Therefore, the engine always assumes a WOT condition and my engine runs rich (of course I have other failed sensors that are causing it to run rich too). I'm curious what the affects on performance would be if I just disconnected the WOT switch. Since its a normally open switch, an open connection wouldn't matter. Of course, if I needed to put the pedal down (going up a hill, or hitting a headwind), I wouldn't have that extra response from the injectors. Anyone got any thoughts?
post #8 of 9 Old 03-27-2013, 09:45 AM
Que89YJ
I have looked and I can find a production source. I can't believe that it isn't sourced anywhere. A cherry switch should work but it will have to be mounted correctly. I am looking now too. Maybe we should try posting on the older XJ forum as well. They used the switch as well as the wagoneer.
Que89YJ is offline
post #9 of 9 Old 03-27-2013, 09:07 PM
ShArKtRaInEr
I got lucky. After giving up trying to find one, I freed mine up via squirting a shot of wd-40 at the pivot point and working it back and forth for a few minutes. Now it doesn't stay stuck in WOT anymore.
new headers, wide open throttle at start rutacon05 YJ Wrangler Technical Forum 4 07-11-2008 03:37 AM
Carter BBD Wide Open Throttle switch. Talos YJ Wrangler Technical Forum 2 04-17-2008 05:56 PM
HOW TO TEST: WOT (wide open throttle) Switch Big-n-Broke-YJ YJ Wrangler Technical Forum 4 01-29-2007 10:22 PM
Need Help!!! Throttle wide open when starting NCST8TJ TJ Wrangler Technical Forum 5 05-21-2005 10:18 PM
Throttle Stuck wide open jeepofun TJ Wrangler Technical Forum 10 12-02-2004 08:01 PM
