Why would there be oil in my air intake - JeepForum.com
post #1 of 3 Old 04-25-2013, 05:58 PM Thread Starter
offroadnick
I just got a 1991 jeep wrangler renegade i checked the air intake and there was oil on the filter and in the bottom of the box there was also oil coming out of the top of the motor were a tube goes from the ar intake to the top on the valve cover
offroadnick is offline
post #2 of 3 Old 04-25-2013, 06:26 PM
SeanB95YJ
that's called "blow-by"
it seems to be common with the Jeep motors... and yours doesn't look too bad really.
that said, the only thing I'm aware of to get rid of (or at least minimize) the problem is to clean (or possibly replace) the pcv and the baffles under the valve cover
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 3 Old 04-25-2013, 08:24 PM
4.7stroker
I agree clean out the PCV/CCV system including removing the valve cover and cleaning out the baffles.
Ensure that all of the hoses are clear and not cracked/broken.
Beyond that would require having the cylinders honed and install new rings at a minimum, from what I can see that would be overkill.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
