why won't a TJ top fit on YJ frame? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > why won't a TJ top fit on YJ frame?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting SleevesJeep Grand Cherokee Grills
Unread 08-23-2011, 04:29 PM   #16
andybloch1
Which Best Top?
Never ascribe to malice, that which can be explained by incompetence.
—Napoleon
andybloch1 is offline   Reply With Quote Quick reply to this message
Unread 08-23-2011, 04:30 PM   #17
Xpress
Super Top.
I drive a Cherokar.
Team Hitec.
Xpress is offline   Reply With Quote Quick reply to this message
Unread 08-23-2011, 08:39 PM   #18
Noltz
YJ Wrangler
I've got a YJ Supertop and it's pretty decent as far as up-down goes. I swapped to a family style bar, and it's quite tight to slide past the rear corners, but it does clear with the pads on. Pads off it'd probably not touch.
I read this Pirate writeup of a TJ top on a YJ with custom cage. He tacked a bracket onto his cage to use the TJ bars, then cut openings into his windshield frame to use the TJ clips up front. YJ doors, he says, are 1" too short and will need to be swapped to TJ doors. You can read the thread there. He's also on jeepkings.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4˝" & shackles, BFG 33's (sold)
Noltz is offline   Reply With Quote Quick reply to this message
