Why wont ANY bolts come out for me..(bolts holding the seats in) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Why wont ANY bolts come out for me..(bolts holding the seats in)
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 09-02-2006, 05:57 PM   #1
GarageBoy
I have new bestop seats in, but I stripped out the bolts holding them in..what's the trick guys?
Thanks
GarageBoy is offline   Reply With Quote
Unread 09-02-2006, 06:00 PM   #2
NCCJ7
Get some PB Blaster and spray the bolts on the bottom side of the carriage. Let them soak over night, then try again.
NCCJ7 is offline   Reply With Quote
Unread 09-02-2006, 06:15 PM   #3
GarageBoy
I'll give that a shot..
The Liquid Wrench didn't seem to do anything
Unread 09-02-2006, 06:33 PM   #4
ZIMSJEEP
I used an impact wrench with a deep end socket on mine...came right off
3.5" Fabtech lift, 5/8" MORE Boomerang Shackles, Brown Dog Motor Mounts, 33x12.5 Mikey Thompson Baja Claws, MT 15x8 Classic II Alloys, JKS swaybar disco's, Rancho RS 5000 stablizer, Skyjacker Hydro 7000 shocks, Warn Bumper w/ pre runner, On board air, Grant Wheel, PIAA Windshield mounted lights, Herculined Interior
ZIMSJEEP is offline   Reply With Quote
Unread 09-02-2006, 07:03 PM   #5
93Renny
x2, pb works wonders, especially if you do it over the course of several days. Try it tomorrow if it doesn't come loose, spray and repeat. It'll eventually break loose from using it, or enough force.
1993 Jeep Renegade, 4.0 I6, 2.5 Rubicon Express Lift kit, 1 inch Shackles, BFG 32x11.50x15
Other add ons, TJ style Stainless hood catches, custom tow hitch......
93Renny is offline   Reply With Quote
Unread 09-02-2006, 07:39 PM   #6
theboxman71
u need a long breaker bar as well...
theboxman71 is offline   Reply With Quote
Unread 09-02-2006, 07:50 PM   #7
Josephrk24
Lefty Losey, Righty Tighty ....
1990 YJ I6 258 AX-15 NP 231 *Now with Posi-Lok*
5 Inch BDS Lift
33X13.50 Mickey Thompson BaJa Claws
Early YJ club member #29
Josephrk24 is offline   Reply With Quote
Unread 09-02-2006, 09:03 PM   #8
jimmylev
I've gotten mixed up a few times. Mostly when upside down or reaching behind something to losen or tighten.
j
Old accountants don't die, they just lose their balance
jimmylev is offline   Reply With Quote
Unread 09-03-2006, 05:57 AM   #9
crosschecker
1995 XJ Cherokee
A zip wheel and grinder works wonders.
crosschecker is offline   Reply With Quote
Unread 09-03-2006, 08:10 AM   #10
superjustin
WD-40 on the bolts, soak them ! Then use a breaker bar aka impact wrench. This method worked on old 10+ years rusted bolts holding the back seat down.
good luck,
justin
superjustin is offline   Reply With Quote
Unread 09-03-2006, 09:48 AM   #11
Mark_ZZ3
A trick that works for me; once the bolt starts turning out, spray the top side (where the socket goes) with pentitrating oil, and then tighten it back in. Each time you loosen it, go a little further, and repeat. This will saturate the threads with oil.
When using brute force in the past, I've just busted bolts. The back and forth method seems to work better for me.
Mark.
Mark_ZZ3 is offline   Reply With Quote
Unread 09-03-2006, 10:02 AM   #12
bobbert350
i had the same problem...umm u have to make sure ur flat against the bolt..use some pb blaster also...after that get a breaker bar and put a steady pressure on the bolt...to put too hard tho...if that doesnt work heat the bolts up....and by some chance if u strip them go to sears and i mean sears or kmart and get a craftsman stripped bolt remover and hammer that on then when finished take them back and say u didnt like them satisfaction gaurentteed remember that..the only reason i say is that they make good quaility stuff for pretty cheap....o yea if u cant get them off still get a cold chizzle and try to do it from there try to turn it with a hammer and cold chizzle by hitting it in the loosening direction it may be stuck by rust that works sometimes
bobbert350 is offline   Reply With Quote
