why won't a TJ top fit on YJ frame? - Page 2 - JeepForum.com
post #16 of 18 Old 08-23-2011, 04:29 PM Thread Starter
andybloch1
Which Best Top?
Never ascribe to malice, that which can be explained by incompetence.
—Napoleon
andybloch1 is offline
post #17 of 18 Old 08-23-2011, 04:30 PM
Xpress
Super Top.
All about that unibody life.
Xpress is offline
post #18 of 18 Old 08-23-2011, 08:39 PM
Noltz
YJ Wrangler
I've got a YJ Supertop and it's pretty decent as far as up-down goes. I swapped to a family style bar, and it's quite tight to slide past the rear corners, but it does clear with the pads on. Pads off it'd probably not touch.
I read this Pirate writeup of a TJ top on a YJ with custom cage. He tacked a bracket onto his cage to use the TJ bars, then cut openings into his windshield frame to use the TJ clips up front. YJ doors, he says, are 1" too short and will need to be swapped to TJ doors. You can read the thread there. He's also on jeepkings.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4˝" & shackles, BFG 33's (sold)
Noltz is offline
YJ Frame differences? Can I frame swap any platform Nate M YJ Wrangler Technical Forum 5 10-26-2010 09:17 AM
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 12:34 PM
rigid frame or flexible frame blackcat471 TJ Wrangler Technical Forum 8 08-12-2009 02:18 AM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
How diff is TJ windshield frame and YJ frame? darioc YJ Wrangler Technical Forum 6 02-09-2008 04:30 PM
