Why use daystar BL? - JeepForum.com
post #1 of 12 Old 01-18-2009, 09:11 PM Thread Starter
chadroc
Why use daystar BL?
I see a lot of recommendations for daystar 1" bodylifts. They seem overpriced. Why use them over other less expensive kits like performance accessories?
chadroc is offline
post #2 of 12 Old 01-18-2009, 09:15 PM Thread Starter
chadroc
And really..... Don't hockey pucks work just fine for a 1" BL? Is there anything involved with a kit other than the spacers and longer bolts and washers?
chadroc is offline
post #3 of 12 Old 01-18-2009, 09:29 PM
asbury
for starters you will be replaceing the old worn out rubber body mounts with new polyurathane mounts that are
1" taller than stock all bolts and hardware inc, and you can get them in red or black
with pucks you are stacking new parts on top of old dry rotted rubber mounts , yes you get new hardware with this kit too , but in my opinion these kit's look cheap , and only come in black
JEEP NAKED !!
asbury is offline
post #4 of 12 Old 01-18-2009, 09:32 PM
notmyj
Well, the daystar kit replaces the whole body mount. Not just a spacer. On most yjs the body mounts are rotted and weathered to a point that they should be replaced anyway. Instead of buying the body lift and new body mounts seperate, you can just get the Daystar kit and know that every thing is new, with good body mounts and a quality body lift.
Bottom line, get the Daystar. Kills two birds with one stone.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #5 of 12 Old 01-18-2009, 09:34 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I agree completely.
FWIW, avoid the red poly ones. Mine turned orange in about 12 months. The black ones on my wife's '93 YJ still look like new.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 12 Old 01-18-2009, 09:48 PM
Barrio
Doesnt the Daystar kit also come with a fan shield bracket too?
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #7 of 12 Old 01-18-2009, 09:49 PM Thread Starter
chadroc
Good point about replacing the original mounts! Daystar it is.
I'll be getting black for sure! I never really understood why anyone would want red.
chadroc is offline
post #8 of 12 Old 01-18-2009, 09:50 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Nope, but the YJ kit does come with the drop down bracket needed for a TJ T-case shifter that you can sell/trade to your TJ friend that bought the cheap a$$ BL kit.
Mean Max is offline
post #9 of 12 Old 01-19-2009, 08:38 AM Thread Starter
chadroc
I haven't been cutting corners on this project, so there's no sense in buying a cheap BL. About the puck idea.... If u would have chose to go that route I would have used a hole saw to make the spacers match the body mounts. I think they would have blended right in
chadroc is offline
post #10 of 12 Old 01-19-2009, 08:46 AM
MLJeeper
MLJeeper's Avatar
For reasons others stated its simply the highest quality BL made. If they had a 2" BL id rock it! <insert flip off smiley here>
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #11 of 12 Old 01-19-2009, 09:24 AM
Ustabearenegade
Ustabearenegade's Avatar
I have installed a few of those and I was always impressed with the "completeness" of the kit, it includes everything to change out the whole thing.
Kinda wish I had gone that route instead of my MORE aluminum system.
"Negative....I am a meat popsicle"
Ustabearenegade is offline
post #12 of 12 Old 01-19-2009, 09:30 AM
jbolty
jbolty's Avatar
x 10, BUT the kit does not include the inner metal sleeves. That's the only part you re use.
jbolty is offline
Daystar BL and Linkage Sallad TJ Wrangler Technical Forum 2 06-05-2009 07:46 PM
Daystar to the rescue hogwild63 JK Wrangler Technical Forum 4 08-19-2007 11:11 PM
What is the torque for a daystar BL??? theboxman71 YJ Wrangler Technical Forum 20 07-13-2007 07:18 AM
Daystar BB jim80proof TJ Wrangler Technical Forum 9 11-09-2006 10:18 AM
1" Daystar BL TrappG TJ Wrangler Technical Forum 17 12-17-2004 06:00 AM
