why is there water comin from under my dash? - JeepForum.com
post #1 of 16 Old 11-25-2006, 03:47 PM Thread Starter
Git-R-Done
Like the title says. there us water dumping/running from under my dash after i wash my jeep. its happened twice now. does it have something to do with the vent on the hood in front of the window? How do i stop this, im tired of wet feet.
Git-R-Done is offline
post #2 of 16 Old 11-25-2006, 03:51 PM
BIGWILL78
BIGWILL78's Avatar
You can search through the threads on here, there is someone that asks this every day, and it is in the FAQ's as well. More than likely it is just what you are looking at. There is a drain hose that comes out of that vent on the back of the firewall and runs straight down, this hose gets clogged and the water comes into the vent system and out. Check that first of all. After that check out your windshield and your cowl seal between the windshield and the body. Good Luck.
1997 Jeep TJ 2.5 4" Pro Comp Lift, 32" BFG AT's
BIGWILL78 is offline
post #3 of 16 Old 11-25-2006, 03:52 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
You need a new cowl seal.
Either that or the drain tube (pass side along firewall) is clogged.
Either that or you own a YJ, they all leak.
- Ernie
Richmond88yj is offline
post #4 of 16 Old 11-25-2006, 03:53 PM
toomanytoys
Could be a few things. One as you mentioned is the cowl vent. The other could be your windshield to firewall seal. The other could be your cowl to firewall body seal. It's caulked more or less from the factory. After a while it deteriorates. Check other other two options first, as they are the easiest to fix. If it's your body leaking, grap a bucket of roof tar and prepare to take to dash out to fix it right.
toomanytoys is offline
post #5 of 16 Old 11-25-2006, 03:57 PM Thread Starter
Git-R-Done
well i know its not the windshield cuz i just redid the windsheild frame and put a new window in. so ill check that drain hose, and the seal on the vent. Thanks
post #6 of 16 Old 11-25-2006, 04:12 PM
Richmond88yj
Eat, Sleep, Jeep
Originally Posted by Git-R-Done
well i know its not the windshield cuz i just redid the windsheild frame....
The cowl seal is below the windshield, it's where the windshield and tub meet, right at the hinge point.
- Ernie
post #7 of 16 Old 11-25-2006, 04:21 PM
chico166
chico166's Avatar
cleaned my drain tube two weeks ago beacuse it seemed like a gallon would pour on my shoes after a light rain. Since then we had two good sets of rainy days and not a drop of water inside.
chico166 is offline
post #8 of 16 Old 11-25-2006, 04:22 PM Thread Starter
Git-R-Done
Oh ok. Thanks.
post #9 of 16 Old 11-29-2006, 11:44 AM
cody11ca
check the drain on the firewall on the passenger side. Looks like a black condom. Mine was full of mud and junk and wouldnt let any water drain. and so the water run under the dash pouring onto my feet.
cody11ca is offline
post #10 of 16 Old 11-29-2006, 12:25 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Could you please elaborate on this? where would the body allow leaking? I am having trouble finding a leak of my own, that whole remove the dash thing does not sound promising...
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #11 of 16 Old 11-29-2006, 07:37 PM
toomanytoys
Hmm, how do I put this. Looking at the Jeep from either side, put your hand on the body right behind the hood. Then move it back toward the windshield. The line that is caulked from the factory deteriorates after a while. It will be the crack that is right under your windshield, in front of your doors, and above where the fender mounts to the tub.
post #12 of 16 Old 11-29-2006, 07:38 PM
JeepTransformer
Yes, it is the vent on the hoood
buy a hood scoop for like 20$
2nd GEN CUMMINS, Manual, Stock
brraaap
JeepTransformer is offline
post #13 of 16 Old 11-29-2006, 08:00 PM
chico166
chico166's Avatar
I bought one of those in addition to cleaning the drain tube and haven't had a drop of water in mine since. I bought the sccop that crews in with the original holes instead of the adhesive one.
chico166 is offline
post #14 of 16 Old 11-30-2006, 07:03 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I got ya, thanks a lot!
I have another question... can't you just apply clear silicone on top of this caulk to stop the leak instead of removing a bunch of things to get under the dash? With patience and skill you can make it look decent I think...
Fernando is offline
post #15 of 16 Old 11-30-2006, 05:38 PM
toomanytoys
You probably could on the drivers side, if that's where your leak is. On the pass. side, there's really no good way to get to it without the dash out. The only reason I done it the way I talked about, was because I already had my whole dash out for some other stuff. Looks aren't really important. Once everything is back together, you can't see any of it. Heck the factory job looks like crap. I guess since we're having this thread, it works like crap too.
water from under dash? Michaeld1187 TJ Wrangler Technical Forum 4 08-27-2009 04:31 AM
Water under dash???? hendu3270 YJ Wrangler Technical Forum 4 04-19-2008 11:10 AM
water from my dash freedom5 TJ Wrangler Technical Forum 15 09-18-2006 04:29 AM
water under dash crb577 YJ Wrangler Technical Forum 5 06-08-2006 09:59 PM
Water in Dash yj_problemchild YJ Wrangler Technical Forum 4 04-04-2005 08:35 PM
