Why not have one more build thread? 94 Sahara - Page 2 - JeepForum.com
post #16 of 43 Old 03-01-2013, 02:53 PM
jsawduste
2006 YJ Wrangler
Prep, prep and more prep. If you think your done go back and prep some more tonight.
Then line it over the weekend.
jsawduste is offline
post #17 of 43 Old 03-02-2013, 11:30 PM Thread Starter
ShaMDog
A few cell phone pics of the herculiner all done. Gonna let it dry and star reassembly tomorrow. Love the way it looks!
ShaMDog is offline
post #18 of 43 Old 03-26-2013, 08:23 AM Thread Starter
ShaMDog
Alright. So it's been a few weeks since I updated this. I will try to get some pictures this afternoon. It has been a BUSY few weeks for me so all I've had time to do is troll the forums for answers. Anyhow, it's all back together. Painted the top flat black with some fabric and vinyl paint, fixed some of the PO's wiring nightmares, fixed my heat(should have done this sooner! It's cold here!), mounted my jack on the hood, swapped in a new Optima red top, and pulled the factory ac. I left the compressor on and ordered the stuff I need for OBA, so when that gets here I'll have another project to knock out. Got some Bilstein shocks on the way from Kolak, and I have a 4000w power inverter sitting on a shelf waiting to be installed. The list of things to do is quickly growing. Now, I have a few questions for the forum... I am leaning towards doing a SOA instead of getting a larger lift. With my 3.5 I have it should net me about 8.5 inches, correct? Now, should I wait until I get the 8.8 to do this or just fab up some new mounts when I put the 8.8 in? Also, with the ac being pulled, what is the ac kit worth with everything minus the compressor? Is there a market for used ac systems on here? And my last question is, I know the rear can't handle over 33's but when I put the 8.8 on it I know it can. But, what about the front? Can it handle 35's without any real modifying? Also, with roughly 8.5" of lift, should I stick with 35's or get 37's?
Sorry. Lots of things running through my head. Thanks in advance!
ShaMDog is offline
post #19 of 43 Old 03-31-2013, 06:59 PM Thread Starter
ShaMDog
Ok, pictures tomorrow. I promise! Anyone have any input to my questions?
ShaMDog is offline
post #20 of 43 Old 03-31-2013, 08:20 PM
Louie4
"You pass butter"
Louie4's Avatar
I remember when my Sahara used to look like that. Our front drivers seats match up pretty good though. I'm planning on some Cavalier seats at some point. I have sewed it back together many times but it's reached its limit on repairs.
As for your questions. An SOA is fairly involved. You have to consider steering, axle wrap, new driveline angles etc. Plus using 3.5" lift springs will put it way up there. You don't necessarily need 8.5" of lift to run 35's or 37's. Most of that can be with modifying the body, small body lift and shackle lift with a combination of lift springs. If you do go SOA I would consider springs with 0-1" lift. As far as the axle strength yes the 8.8 will handle 35's. The D30 will run them but keep spare shafts. Some guys upgrade to the larger u-joint XJ and TJ shafts and others build trusses and sleeves etc. The A/C system can be sold relatively easy since a lot of folks want them. A complete aftermarket kit is around $900 but I wouldn't try to sell a stock system for that much.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #21 of 43 Old 04-01-2013, 09:18 AM Thread Starter
ShaMDog
Well I've already considered the steering and driveline issues I will encounter, but what should I do to deal with axle wrap? So, do you think I should dump the black diamond lift that's on it and take it back to stock springs for the soa? I had debates this from the get go but just tossed the idea because I assumed it would be ok. As far as the ac goes... Looks like there will be some new ac stuff on eBay tonight. Lol. Thanks for the input. I'm pretty new to the jeep world and have a lot to learn.
ShaMDog is offline
post #22 of 43 Old 04-01-2013, 07:44 PM Thread Starter
ShaMDog
Alright... as promised. This is as she sits today. I washed it and took some pictures.
ShaMDog is offline
post #23 of 43 Old 04-02-2013, 06:48 PM Thread Starter
ShaMDog
Well, shocks came in the mail today. And I also have a new project! Going to swap in some 4" round led tails after finding out my drivers taillight is broken as hell.
ShaMDog is offline
post #24 of 43 Old 04-02-2013, 07:06 PM
Louie4
"You pass butter"
Louie4's Avatar
So what tire size are you planning on running and what type of terrain will your jeep mostly see? This will help determine what to do with your suspension. I run the same 3.5" Black Diamond springs and have had success. When I go to a 35" tire I am going to look into a SOA suspension with 0-1" lift.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #25 of 43 Old 04-02-2013, 07:17 PM Thread Starter
ShaMDog
Well, I'm mostly looking to use it as a DD to and from work and hit some trails/camping on the weekends. I'm leaning towards 35's but I really wouldn't be opposed to 37's if I could pull them off. So do you think I should ditch the BD springs and go back to stock or a shorter lift? I suppose I could go back to stock and get some shackle lifts. Also debating a 1" body lift to get some more clearance for the suspension to articulate.
ShaMDog is offline
post #26 of 43 Old 04-02-2013, 08:14 PM
Louie4
"You pass butter"
Louie4's Avatar
If you go SOA then yes you should look for springs with little to not lift. However, you may want to stick with the smaller tire sizes for a DD and weekend warrior. It will keep the gas cost down and may add some life to the drivetrain components or you could have two sets of tires. One for the road and one for the trails. I wouldn't ditch the Black Diamond springs but rather keep an eye out for stock ones depending on your plan.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #27 of 43 Old 04-02-2013, 09:15 PM Thread Starter
ShaMDog
So you think 35's would be ok for a DD or should i run done 33's for street and 35's for trail? You think soa with stocks on a 1" shackle lift and a 1" body lift would be too much?
ShaMDog is offline
post #28 of 43 Old 04-05-2013, 04:53 PM Thread Starter
ShaMDog
New shocks went in today. Got out of work early and took advantage of the amazing weather here in TN today. Took me about an hour and a half but the difference is amazing! The old Black Diamond shocks had nothing left in them. They were WAY overdue for replacement. Anyhow, on to the pictures...
Pulled into the garage and ready for some TLC
The new shocks are in. Thank you Kolak for the great deal!
Old shocks coming out
The old BD shocks fully extended(I had to do this. they didn't move at all on their own)
Fully compressed. Again, no movement from the shocks. No wonder the ride was so rough.
Bilstein's in!
Added a little more to the garbage pile that I've pulled off the ole YJ.
ShaMDog is offline
post #29 of 43 Old 04-05-2013, 05:48 PM
flashy
You could do waggie springs....then you get the lift from the springs...you get lift from the SOA...plus you get 4" of stretch from the springs. But I'm kinda bias cuz that is what doing!! LOL
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
post #30 of 43 Old 04-05-2013, 05:53 PM Thread Starter
ShaMDog
Waggie springs eh? I'm going to have to search that one. It's a new one to me.
ShaMDog is offline
