Why are my lights going crazy? - JeepForum.com
post #1 of 3 Old 08-09-2010, 06:33 AM Thread Starter
k2enemy
When I turn my right or left blinker on both blinker lights come on and stay on, the speedo and tac lights flash and both outside turn markers flash. It does the same with the lights on too. Where do I start? There is no reason to believe any wiring is mismatched, how does this even happen?
k2enemy is offline
post #2 of 3 Old 08-09-2010, 09:33 AM
idaholtby
Make sure that you have the right lamps installed for the turn signals. If 1156 (single center contact base) is installed rather than the 1157 (dual contact) then the 1156 will short the two contacts in the base connector together and cause the voltage to back feed through these circuits and cause this very symptom. Easy thing to do as these lamps are identical in every way other than the single or dual filaments (contacts). This may not be the cause of your problem, but should be ruled out before chasing grounds.
idaholtby is offline
post #3 of 3 Old 08-09-2010, 06:36 PM Thread Starter
k2enemy
Thats a good point, I did change the bulbs when I had the lighting harness out. I think I used the correct bulbs but who knows. Well...I didn't use the correct bulbs. That did the trick, thanks!
k2enemy is offline
won't start dash lights and gauges go crazy orenjr TJ Wrangler Technical Forum 4 08-16-2016 06:34 PM
crazy brake lights!!!! whitetj TJ Wrangler Technical Forum 6 03-11-2010 02:53 PM
Brake lights Gone Mad Crazy bcameron1974 YJ Wrangler Technical Forum 4 04-04-2009 02:48 PM
brake lights driving me crazy driller_26 YJ Wrangler Technical Forum 5 03-10-2009 08:42 AM
Dash lights driving me crazy AbsolutEdge TJ Wrangler Technical Forum 10 07-09-2005 02:04 PM
