Why is this my daily driver! - JeepForum.com
post #1 of 6 Old 08-24-2011, 11:01 AM Thread Starter
heyitslou
1987 YJ Wrangler
Frustrated jeep owner beware...Ok here's the deal drove the jeep.last night no issues this morning (late for a meeting) jumped in the jeep and found that the clutch has no pressure checked the fluid and its empty. I know that the 87 has an.internal slave which means dropping the transmission (again! Just had it done to replace the flywheel). I'm hoping its the master cylinder leaking this may be a stupid question but how can I tell. if the master is bad?
heyitslou is offline
post #2 of 6 Old 08-24-2011, 11:15 AM
oldtime_ironman
Hi, welcome to the club! You just found one of the best jeep sites anywhere.
You can tell if the master is leaking by looking up behind the dash, on the vertical part of the firewall. If its leaking, then there will be fluid running down, or a wet spot.
oldtime_ironman is offline
post #3 of 6 Old 08-24-2011, 11:53 AM
NonRubicon
In addition to what oldtime_ironman has stated, make sure all the hydraulic lines are in good shape and that the connections are goodntight. You can also check for any fluid dripping from the bellhousing.
NonRubicon is offline
post #4 of 6 Old 08-24-2011, 12:12 PM Thread Starter
heyitslou
1987 YJ Wrangler
How many hydraulic lines are there and where do they run to.and from?
post #5 of 6 Old 08-24-2011, 12:34 PM
91BoD
There is 1 and it runs from master to slave.
91BoD is offline
post #6 of 6 Old 08-24-2011, 12:42 PM
NonRubicon
There is also the bleed line from the slave. Make sure there isn't any fluid escaping from there as well.
