Why Herculiner? - JeepForum.com
post #1 of 17 Old 11-04-2008, 08:42 PM Thread Starter
matt111399
Why Herculiner?
What's the deal with Herculiner on the floor boards? I see all the posts on how to do it, prep, ya ya ya....but no explanation on why and what the benefits are. Thanks for the input...
Matt
matt111399 is offline
post #2 of 17 Old 11-04-2008, 08:47 PM
Krautzy
AAAAAWWWWW------DUDE!!!!! Rust-proofing, sound-deadening, no-slip surface, color change, texture change, man,chicks dig it!!!!!
Krautzy is offline
post #3 of 17 Old 11-04-2008, 08:47 PM
stu1021
I had my tub Rhino lined - some of the reasons were:
No maintenance
No soggy carpet
reduced interior noise level
cooler floorboards under my feet
rust prevention
Mine also wraps over the top of the tub and around the door and tailgate openings so I don't have to worry about scratching the paint when removing/installing the hard top or doors.
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
post #4 of 17 Old 11-04-2008, 08:47 PM
Krautzy
And its easy !
Krautzy is offline
post #5 of 17 Old 11-04-2008, 08:53 PM
h2osprt
[QUOTE=stu1021;5950736]I had my tub Rhino lined - some of the reasons were:
No maintenance
No soggy carpet
rust prevention
STU1021
Is it really cooler or at least as cool as carpet? Heat is my big concern and why I haven't done it yet.
h2osprt is offline
post #6 of 17 Old 11-04-2008, 09:35 PM
timatoe
timatoe's Avatar
I ran mine with no carpet for about a year and a half and never noticed any real increase in heat. Herculiner is good for all the reasons mentioned and it cheap and easy to do.
timatoe is offline
post #7 of 17 Old 11-04-2008, 09:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Okay, so my '91 has Herc inside, and my wife's '93 doesn't (yet!) and here's the reason I like having it.
I was driving her YJ the other day, and my cellphone starts ringing while it's in my front pocket. I raise my arse up a bit to retreive it, while bracing my left foot on the floor to push against. My foot kept slipping on her slick floor, and being as I use the same manuver in my YJ with no problem, that's a good enough reason for me.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 17 Old 11-04-2008, 09:44 PM
Krautzy
Herky-liiinur
I hears ya! No slippee !
Krautzy is offline
post #9 of 17 Old 11-04-2008, 09:52 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by nomorejeeps1 View Post
yep only nerdy jeep guys do this mod
Back under your bridge troll.
Mean Max is offline
post #10 of 17 Old 11-04-2008, 09:53 PM
BlackRhino
BlackRhino's Avatar
The main reason I did it was for rust protection. Second is the no-slip grip, and third because it just looks darn good! Plus it's (relatively) cheap.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #11 of 17 Old 11-04-2008, 09:55 PM
joe's_yj
joe's_yj's Avatar
i dont run a top in the summer and i dd it, so having water in my jeep is a common occurance. after a while of getting in and out the paint will wear off your floor boards, and rust. Herc will not do this.
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #12 of 17 Old 11-04-2008, 09:57 PM
BamianYJ
93 YJ 2.5 AX5 NP231 33" BFG,8.8, 4.88s, SS SYE, SOA, OME 2.5", 1" BL, 5/8" Booms
BamianYJ is offline
post #13 of 17 Old 11-04-2008, 09:58 PM
BamianYJ
So true...
BamianYJ is offline
post #14 of 17 Old 11-04-2008, 10:01 PM
ksm4_al
Wash and wear. After a day in the Alabama mud it's easy to hose it out and let it air dry.
ksm4_al is offline
post #15 of 17 Old 11-04-2008, 10:02 PM
provinT13
Darker color on the inside is also nice if you dont have carpet. I have a red yj and looking back at the bright red inside compared to the black herculiner, it's much easier on the eyes, and the no slip surface is nice.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
Herculiner YJBully YJ Wrangler Technical Forum 7 06-15-2007 12:52 PM
Covering Herculiner with Line-X (or another coat of Herculiner) frankiejr TJ Wrangler Technical Forum 3 05-01-2007 08:27 PM
Herculiner bmx_hb_guy YJ Wrangler Technical Forum 9 01-11-2007 02:27 PM
Herculiner on top of POR-15??? theboxman71 YJ Wrangler Technical Forum 12 12-13-2006 11:05 AM
Herculiner jeepteejay TJ Wrangler Technical Forum 10 09-29-2006 05:55 PM
