Why? ground out wire? - JeepForum.com
post #1 of 19 Old 12-06-2011, 04:33 AM Thread Starter
nickmonaco
Something gives me the feeling my YJ isn't the only one doing this...
infact if you have pictures of things your YJ does, simply because its a YJ put em up and let's see what we all have in common lol
WHITE JEEP CLUB #171
My other Jeep's not a Chrysler.
nickmonaco is offline
post #2 of 19 Old 12-06-2011, 06:11 AM
91jeeepsahara
Ya tha happens in alot of jeep just go to the scrap yard and get another cluster or get a single gauge and install it I've had that happen to two of my jeep real easy fix
91jeeepsahara is offline
post #3 of 19 Old 12-06-2011, 08:44 AM
94chb
its common if you take the gauge cluster out and look at the back of it you will see the ribbon all messed up. ive soldered mine several times. i got tired of smacking it lol.
94chb is offline
post #4 of 19 Old 12-06-2011, 09:00 AM
Que89YJ
Check the wire to the temp sensor by grounding it. It should go to 0. The temp guage sensor is the one on the rear of the block with a single wire going to it. If you ground it and the guage doesn't move then the guage is bad. If it does go to 0 then the sensor is bad:
http://www.jeepforum.com/forum/f12/2-5l-sensor-553520/
Que89YJ is offline
post #5 of 19 Old 12-06-2011, 09:44 AM Thread Starter
nickmonaco
THANK YOU sounds like a plan. I just bought a test light and meter and a whole bunch of **** too
post #6 of 19 Old 12-06-2011, 10:00 AM
MegaCabMan
FYI>>>
be sure to pull your ground cable before you pull that cluster. I grounded out the clock connection (always hot) and fried the ribbon cable.
My bet is that the wire to the sending unit is grounded on the block, or the sending unit is bad.
MegaCabMan is offline
post #7 of 19 Old 12-06-2011, 10:15 AM
YJames90
YJames90's Avatar
Mine did that last week but it was from overheating
My 2.5 to 4.3 swap thread
YJames90 is offline
post #8 of 19 Old 12-06-2011, 01:06 PM
hdfxrs91
1987 YJ Wrangler
Mine does that, too. I just tap on it, or hit a bump, and it goes back to where it's supposed to be, then just falls again later.
hdfxrs91 is offline
post #9 of 19 Old 12-06-2011, 01:23 PM
pasinbuy
Originally Posted by MegaCabMan View Post
FYI>>>
You mean the positive, red cable on the battery? Not the ground, right?
pasinbuy is offline
post #10 of 19 Old 12-06-2011, 02:35 PM
Que89YJ
Doesn't matter. I usually disconnect the ground at the battery.
Que89YJ is offline
post #11 of 19 Old 12-06-2011, 05:41 PM Thread Starter
nickmonaco
Its not always in one place it dances around a clicks left and right like crazy sometimes too
post #12 of 19 Old 12-08-2011, 08:34 AM
MegaCabMan
Disconnect the ground first.
They call me the King of Fun! Everwhere I go I hear "Here comes that Fun King MegaCabMan"
post #13 of 19 Old 12-08-2011, 09:48 AM
oldtime_ironman
You might want to clean the contacts on the circuit board behind the gauges. It has worked very well for me in the past. The big clue is that you are tapping the gauges and they change - that is a sign if dirty or broken connection. Here's a write-up how to do it, its pretty easy.
http://www.jeepforum.com/forum/f12/r...ter-how-991307
Give that a shot and post back. Just FYI Morris4x4 has the whole circuit board replacement for something like $75. In my case I simply hard-wired the gauges in with solder.
oldtime_ironman is offline
post #14 of 19 Old 12-14-2011, 09:06 AM Thread Starter
nickmonaco
Thank you
post #15 of 19 Old 04-08-2012, 08:09 AM
crunk7
1987 YJ Wrangler
frustrated!!
I have done all the things listed here. i evenemp pulled the gauge pod from friend's yj and the temp gauge is still pegged. sometimes it is not pegged when i start, then it pegs.
crunk7 is offline
Ground wire help... MHip TJ Wrangler Technical Forum 10 03-06-2011 08:16 PM
ECU ground wire???? Billsbluejeep YJ Wrangler Technical Forum 3 11-18-2010 03:41 PM
ground wire? nsahan YJ Wrangler Technical Forum 19 05-26-2010 05:09 PM
New ground wire Brandon_YJ YJ Wrangler Technical Forum 2 01-19-2009 12:10 PM
Ground Wire Kit? HuD YJ Wrangler Technical Forum 2 08-23-2006 04:49 PM
