Why do you need a return fuel line - JeepForum.com
post #1 of 9 Old 03-20-2007, 08:56 PM Thread Starter
1989 Islander
Once you put on a MC2100 what purpose does a line going back to the tank serve?
I understand that on the orig system, Carter carb BBD feedback, it was part of a grander scheme but now that one has a 2100 could you get by with just the one line from the pump to filter to carb?
Jeep: A wealth depletion device.
1989 Islander is offline
post #2 of 9 Old 03-20-2007, 09:01 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Because of the valves in the carb only let so much gas in. The rest has to be bled off and not back up pressure to the mechanical pump.
This is called an open loop system
Essentially look at your fuel filter. The drain line is on top, carb feed on bottom. Any "over pressure" condition bleeds out through the top and back to the tanks to be cycled again with little or no pressure.
It extends the life of the pump and keeps the pressure regulated at the carb.
- Ernie
Richmond88yj is offline
post #3 of 9 Old 03-20-2007, 10:06 PM
tuckinauster
tuckinauster's Avatar
i couldn't have said it any better myself
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #4 of 9 Old 03-20-2007, 10:29 PM
Varnish
Varnish's Avatar
Just to give a visual aid, the carb has a little bowl in it that it draws fuel from, there is a needle which rises and falls with a float in the fuel bowl, when the float raises up to a specified point the flow from the feed line is cut off - there's no smarts in the mechanical fuel pump so it just keeps on pumping and that extra fuel has to go somewhere.
'06 LJ, '88 YJ
Varnish is offline
post #5 of 9 Old 03-20-2007, 10:46 PM
Axl Jack
Two years ago my fuel return line became clogged. Normally I'm supposed to have 60 pounds of pressure on my fuel rail (94, has injectors).... but when my return line became clogged I was getting close to 90.
I thought I had a spark problem at first because it seemed sluggish. To test I'd start off in 3rd gear up a slight hill. It would keep running and not stall, so thats when I figured it had to be a fuel problem.
PS: On a side note, after fixing my fuel return line.... about 4 months later my fuel pump went. I had to open up my damn gas tank twice that year.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #6 of 9 Old 03-21-2007, 08:36 AM Thread Starter
1989 Islander
Thanks. I hope this is as informative to others as it is to me. It gives me several thing to check on the carb set up.
This is one I'm glad I asked.
post #7 of 9 Old 03-21-2007, 11:04 AM
vadslram
OOOO I like the picture!
vadslram is offline
post #8 of 9 Old 04-05-2007, 07:09 PM
gordonc_eh
Axel Jack
Have yj 91 4.0 fuel pressure 92 lbs
How/where does the return fuel line get plugged??
Is there a valve at the pump???
Looking at removing tank like to clarify firdt, need pump?????
GC
gordonc_eh is offline
post #9 of 9 Old 03-25-2010, 11:33 AM
lidlitalian
1987 YJ Wrangler
on the filter setup, does the return line go above the inline or below? Think mine is upside down. when I pinch the return line, my holley fpr goes up to the psi (3.5) that it should be. when its not pinched, it just bounces around 0-1...
lidlitalian is offline
Return Fuel line or Carb? ReconBen YJ Wrangler Technical Forum 9 02-11-2010 11:47 PM
Which fuel line is the return? msprooch YJ Wrangler Technical Forum 3 12-08-2009 03:40 PM
Fuel pressure too high - Fuel return line problems ChiroSean YJ Wrangler Technical Forum 4 08-11-2009 09:57 AM
Return Fuel Line Fitting will04wrangler TJ Wrangler Technical Forum 0 03-18-2008 12:58 PM
Fuel return line norsoulnet YJ Wrangler Technical Forum 23 01-18-2007 06:52 AM
