Who's runnin 2.5, ax5, 4.88s and 35"s???
| Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
Mud tuggin!
Anyone running the 2.5l with 5 speed, 488 gears and 35" tires?
Hows the performance? would you recommend the 35s or 33's? Dont worry people, the rear is a D44 and front 30. thanks
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon! Build thread: http://www.jeepforum.com/forum/f22/build-thread-dirty-894483/ |
#2 |
I'm running 4:56 and 36's in mine. It has a 2.5 it runs good, but never use 5th gear and it tops out at a woping 60ish mph but I wish I had a little bigger gear but wouldent trade tire sizes. You should be fine with 35's
#3 |
Im running 35s with 5.13s and its great. I can run 70 easily. you should be fine with 4.88s but i would reccomend 5.13s
#4 |
lol..wish I had 5:13's
#5 |
bye bye mpgs. lol. i wanna run 35's but not w/ my d35 still. i've heard that 35's are a bit much for the ax-5 however
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate] |
#6 |
Mud tuggin!
cant run 5.13 in the D30
#8 |
Don't know about 35's but my 33's are much happier with the 4:88's. I can only think that 35's & 4:88's would be about the same as my 33's were with 4:10's not great.
31's & 4:10's very drivable and fun 33's & 4:10's not much fun and SLOW 33's & 4:88's WOW MORE FUN and very drivable again 35's & 4:88's not much fun and SLOW " I Think "
Not here for a long time, were here for a good time |
#9 | |
Seems like performance varies from Jeep to Jeep, but I run this exact set-up without any issues. The jump from 33's to 35's was hardly noticeable for me. If anything, it was as if I had the same performance I had with my 33's with the stock TB before I added a 4.0 TB (If that makes any sense to you, lol) Hit any longer inclines, and it slows down, but I still hold the speed limit most the time. Higher elevations kill me though... 35's with the AX5 definitely isn't the strongest set-up, but doable. Now towing the amounts of weight I have in the past, with the AX5 and 35's, probably not such a great idea ![]() All in all, I drive the living hell out of mine and I get around fine
92 YJ. Lifted, rubbered, geared, and more |
#10 |
Mud tuggin!
anyone else, im making my final decision on either 33's or 35's next week!
#11 |
if you wheel it get 35's, won't get high centered as much
#12 |
Go with the 35's. I have run both 33's and 35's and like the bigger tires better. I can still run 75 mph on flat ground in 5th gear without a big head wind.
"Our lady of blessed acceleration don't fail me now" |
#13 |
1995 Wrangler
35's, 5.12's 70 MPH no problem. As for the AX5 it is not the best transmission out there but I am 4 years + on this setup now.
#14 |
im running 4.88s and 33's and i like it. Although i can only top out at 70 but anything after 60 has a bad death wobble.
#15 |
I think my 4.10 and 30's is just enough.
You guys are bananas ![]() Jake ![]()
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
