Who's the moron? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Who's the moron?
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-09-2003, 12:18 PM   #1
Slider_88YJ
Who's the moron?
I ordered the sky jacker 2.5" lift from quadratec about a week and a half ago. The guy said the stuff would be here by last tuesday. the entire week goes by and i get nothing. So I'm gettin all pissed wondering where my stuff is, calling UPS telling them their guy F'd up. They said they delivered it blah blah blah. And then just today I see my sister and she says oh hey... there are some boxes underneath the tarp out there with your name on them.... The UPS guy decided to put the delivery underneath a tarp i had sitting in my driveway (cleaning out the garage) because it was raining outside. This was last monday. So am I the idiot for not looking under the tarp or should the UPS guy leave a note or something??
Ok, now that im done venting... I am planning to replace my exhaust from front pipe back with a hi-flow cat and borla catback along with doing my suspension lift with daystar shackles this weekend. Can you guys suggest anything i will need other than an angle grider, my BFH and a case of some fine lager?
'88 Wrangler Sahara, straight 6, 4.2L 258, 5 spd standard
33x12.5 BFG MTRs on Cragar Series 315 rims
GM HEI, Weber 32/36, Nutter Bypass
2.5" Skyjacker Suspension Lift, Daystar Greasable Shackles, 2" Body Lift, T-Case Drop
Dynomax Hi-Flow Cat, Borla Cat-Back
Bestop Trailmax Sport Seats
Slider_88YJ is offline   Reply With Quote
Unread 09-09-2003, 01:05 PM   #2
coolhand
HeHeHe! The same sort of thing happened to me. But it was only one box not an entire lift kit.
As for tools I would sugest a GOOD Pitman arm puller in you got a droped arm with your kit. I broke 3 of the free loners from the Auto parts store before I Just cut it off.
"The Empty Pocket Warriors." Member #2
"92 YJ, 3.5" BDS. Custom 1.5" lift shackles, 2" BL, Ford 8.8 W/Trac-loc & 33" TrXus MT's (for now).
"No one ever accused the Wrangler of being comfortable, quiet, or practical. No one ever called it boring, either. The Wrangler is a two-door toy, ... great fun to drive with the top down." -- AUTOMOBILE MAGAZINE, March 1995.
coolhand is offline   Reply With Quote
Unread 09-09-2003, 01:05 PM   #3
RCHavok797
The UPS guy is at fault, they are supposed to leave a note.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline   Reply With Quote
Unread 09-09-2003, 01:10 PM   #4
19OlllllllO41
its the ups guys fault. it is cool they put the boxes under the tarp to keep em dry, but when they do things like that they are suppose to leave a note on your door saying they left em there. they left some of my stuff in my yard a few times, but always left a note on the door sayin so.
as for the lift tools, like you said a grinder and a bfh!! also the sawsall helps out too. lots of blades and lots of grinder cut off wheels too, those grade 8 bolts can eat em up fast. when it comes to taking the bolts out of the rear spring eye, the best bet is to cut them. most people cant get em to budge. i just cut mine, along wiht most other bolts, and went to mcmaster carr or grainger and picked up new grade 8 hardware. this way will save you tons of agravation. and you said you got the daystars so if the front shackles are giving you trouble cut them too since the daystars come wiht all new nuts and bolts.
[FONT="Arial"][SIZE="3"]
[URL="http://www.jeepforum.com/forum/f22/yj-betty-transformation-1229681/"]'93 YJ (Under Construction)[/URL]
Previous Jeeps:
'83 CJ7
'92 YJ
'00 XJ
'99 TJ
'05 TJ Rubicon[/SIZE][/FONT]
19OlllllllO41 is offline   Reply With Quote
Unread 09-09-2003, 01:10 PM   #5
D4FS4
Might be this guy...
[B]D4FS4[/B]
1994 YJ
D4FS4 is offline   Reply With Quote
Unread 09-09-2003, 01:12 PM   #6
19OlllllllO41
just something bout what coolhand said, you shouldent need the pitman arm puller cause you shouldent have to change the pitman arm. even if the kit comes with one i wouldent put it on, you shouldent need it unless your going with like a 4in+ lift.
Previous Jeeps:
'83 CJ7
'92 YJ
'00 XJ
'99 TJ
Unread 09-09-2003, 02:07 PM   #7
Bob K
I think any lift requires a dropped Pitman arm. The reaso for the dropped pitman arm is to keep the steering components all parallel. If they are not parallel you get bump steer or even binding in extreme cases.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline   Reply With Quote
Unread 09-09-2003, 03:21 PM   #8
TellyDSP
Poland and PPV!!!!
I can't tell if she knew the whole time, but if she did, your sister is at fault. She should have told you the second they arrived. If she didn't know till recently then that blows my theory out of the water.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Unread 09-09-2003, 08:42 PM   #9
igotdoo
Bob I dont totally agree. I mean, yes, you need to keep things parallel from what I read.... mainly the drag link should be parallel with the traction bar.
My lift kit came with a traction bar reloaction braket, which lifts the traction bar attach point 2". The spring lift is 2" Therefore, all the angles are maintained.... everything is still parallel, and no pitman arm needed.... per say.
On mild lifts, 2-2.5" I have not seen any come with or require a pittman arm.
igotdoo is offline   Reply With Quote
Unread 09-09-2003, 08:51 PM   #10
smok3y
do you need a new pitman are for...foresay 2bb/1inch shackle?
1990 YJ/ 31x10.50 Maxxis Mudders/Removed Sway bar,Rear trac bar/tow hooks. 2" straight pipes from manifold back
[COLOR=white]White Jeep Club #73,999,999[/COLOR]
smok3y is offline   Reply With Quote
Unread 09-09-2003, 10:25 PM   #11
igotdoo
BB? A BB (budget boost) is for coil springs.... not leaf springs with shackles.
I assume you mean a 2" BL (body lift) with 1" shackle lift? Froma suspension standpoint, that is only 1" of real lift, and therefore you arent even really affecting your steering angles.
