Who's Got the 8.8 Installed Already? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Who's Got the 8.8 Installed Already?
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-24-2002, 08:58 PM   #1
YJNotDone
Just wondering if this installation would lower your lift in the rear on a spring under axle configuration due to the larger diameter axle tube.
95, 4" susp. lift, 33x12.50 ProComp M/T's, custom square tube bumpers, , energy bushings, 4.0 HO, everything stock, 1" or 2" body lift and who knows what else coming soon.
YJNotDone is offline   Reply With Quote Quick reply to this message
Unread 04-25-2002, 08:06 AM   #2
V8wrangler_idaho
hummm I didn't notice a difrence on mine when i did the convertion on my axles. If it dose change it would only be by a 1/4 inch. it all depends on how tall the spring pearches are on the axle. If the spring pearches are taller then it could effect that but I don't really think that it change the amount of lift at all
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline   Reply With Quote Quick reply to this message
Unread 04-25-2002, 09:30 AM   #3
dreid33
Good article on the 8.8 swap if you have not seen it.
<a href="http://www.off-road.com/jeep/tech/axle/Ford8.8/97.html" target="_blank">http://www.off-road.com/jeep/tech/axle/Ford8.8/97.html</a>
Thanks!
dreid33 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2002, 09:51 AM   #4
Atropine
Man I cant wait to get mine!!!!
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline   Reply With Quote Quick reply to this message
