who's swapped Tj shafts into YJ D30?? HELP - JeepForum.com
post #1 of 29 Old 11-27-2008, 08:19 AM Thread Starter
willyb8
willyb8's Avatar
got the shafts all set and the seal on the drivers side in. i'm having trouble getting the pass side seal to stay in place. everything i've read says theres no seal on outside of the disconnect housing in stock form. mine has one with ID to fit bigger shaft. the seal i got from NAPA #11800 seems to fit into the stock seal but when i put shaft in it just pops out. do i need to RTV it in place? i used a threaded rod with washers on either side to press it in there tight. other people said that the seal for the drivers side will fit on pass side with Tj shafts but i don't see where, will it fit on side of pumpkin like the drivers side does? please help, i'm doing this on a D30 in garage not the one in jeep so its not an emergency. just really frustrated.
91 YJ 4.0 HO,
3.5" BDS, 5/8 MORE Booms, 1" BL, MML
AA SYE & CV,
35" Maxxis Bighorn
Smittybilt XRC8 Winch,
8.8 W/Elocker, D30 W/Aussie
Genright tube fenders
willyb8 is offline
post #2 of 29 Old 11-27-2008, 08:28 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I have never done it but know this is the best write-up out there: http://www.stu-offroad.com/axle/yjd3...jconvert-1.htm
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 29 Old 11-27-2008, 08:37 AM Thread Starter
willyb8
willyb8's Avatar
yeah thats the site i went by to install. i just can't get the outer seal to stay in place.
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #4 of 29 Old 11-27-2008, 08:43 AM
TSEJEEPERS
Sounds like you bent the seal. I would get a new one. To be completly honest with you if you are talking about the seal at the disconnect and you have the one at the pumpkin I would not worry about it.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #5 of 29 Old 11-27-2008, 09:14 AM
93YJfalcon
I had the same issue. I skipped the seal in the houseing for all of the above reasons. I am now two years deep and leak free.
Just to clarify - I have a seal on each side of the pumpkin. They are slightly different sized.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #6 of 29 Old 11-27-2008, 09:17 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
yeah, the TJ shafts don't use one on the outside of the disco housing like the YJ does. even if you were to put on there it won't do any good for long. there's no matching machined surface on the TJ shaft to put one there. you have to pull the carrier and install one on the inside of the diff housing just like the driver side. you may have to do a little grinding to the housing to get it to fit from what I've read, since the YJ housing wasn't machined to put a seal there.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 29 Old 11-27-2008, 09:39 AM
champelite210
All you need are the ones in the housing.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #8 of 29 Old 11-27-2008, 05:26 PM
ctm
I don't understand why that writeup calls for a seal at the disconnect housing. Why would you need it, as said above the axle is not machined for it, and when you put a seal at the differential that's all you should need. At that point it is set up like a TJ or a CJ. I can see where there might be an issue with the passenger side differential seal seat area not being machined for a seal, anyone have an issue with that?
ctm is offline
post #9 of 29 Old 11-28-2008, 08:03 AM Thread Starter
willyb8
willyb8's Avatar
how much different sized?? q-tec said the ones for the driver side will fit on pass?
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #10 of 29 Old 11-28-2008, 08:32 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The above posters are right, a seal at each diff bearing area is all. The YJ seal on the left is fine, works. The 11800 is tapped into the right side inside the diff with the carrier removed (as is the left side should ie need replacing). If you plan to use syn fluid and have not before, I suggest swapping the left side seal too. Seals that saw non-syn fluid tend to leak when syn fluid is later used.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #11 of 29 Old 11-28-2008, 09:55 AM
93YJfalcon
I'm not 100% sure that they are different sized. It seemed like it though. Maybe some yj d30's are a little different It did have to be tapped in with a socket on the end of a broom stick from the end of the housing while one person held it true inside the pumpkin.
I ended up using a Chicago Rawhide (CR) #11340.
For reference I also have the brands that are supposed to work.
Chicago Rawhide 11343 (Same as 11340 just a bit deeper sides)
Napa 11800
National 710068
National 471763
Spicer 42500
Superior Axle 470160
I used the following kit to do my TJ shafts: http://www.4wheelerssupply.com/catal...82bb0f13768e8b
Here's a good thread:
http://www.jeepforum.com/forum/showt...=1#post3259716
post #12 of 29 Old 03-22-2009, 08:41 PM
michaelkkirk
I just did mine.. here are some picts
Driver side seal
Pass side seal
Disconnect seal
Disconnect coverplate.
michaelkkirk is offline
post #13 of 29 Old 03-23-2009, 05:11 AM
JeeperDon
JeeperDon's Avatar
Can you please replace those photos with much smaller, less meg images? It's the internet version of 'be kind, rewind'.
Web Admin for
post #14 of 29 Old 03-23-2009, 06:39 AM
michaelkkirk
Fixed.. they were kinda big.. I have a fast connection so I forget.. :-)
post #15 of 29 Old 03-23-2009, 10:32 AM
tranzamwayno
you only need the two seals on each side of the pumpkin, with diff removed.
the passenger side is smaller than the driver side and there are 2 versions of seal depending on the axle tube size jeep decided to use.
another thing to check is there is a bearing next to the disconnect housing and my shafts were a little larger than the originals so this had to be removed(after i put everything back together the axle slid in only so far, out came the diff again) no big deal with a socket and a few extensions through the housing to pop it out.
tranzamwayno is offline
Yukon Shafts Vs. Alloy USA Shafts rastaangel TJ Wrangler Technical Forum 14 11-23-2009 08:08 PM
Do the rear axle shafts easily pull out like the front shafts? jclark50 TJ Wrangler Technical Forum 2 04-13-2008 10:10 PM
heavy-duty D35 shafts vs. stock D44 shafts jcssurf TJ Wrangler Technical Forum 26 01-07-2008 05:43 PM
Dana 30 spare shafts, what other vehicle shafts will work on the TJ Broadway TJ Wrangler Technical Forum 5 05-03-2007 08:27 PM
XJ front shafts as yj rear shafts after SYE holding up? notch4u YJ Wrangler Technical Forum 6 01-05-2007 01:42 PM
