Who's running a Spartan or Aussie in their D30? - JeepForum.com
post #1 of 16 Old 09-28-2013, 07:26 AM Thread Starter
Rproject
1987 YJ Wrangler
Instead of going down a different path in a previous thread, I decided to make a more specific thread.
I'm 90+% certain I want to put a lunchbox locker up front in my 87. I'm running stock axles, 31's (maybe 32's at some point) and want to know who else is running a Spartan or Aussie locker in their D30? How is it holding up? Any explosions? Axle shaft issues? drive shaft issues? u-joint problems? Where is the weak link?
I've got a few friends who are saying to ditch the 30 and go 44, but I'm not sure I need to go that route. Aussie claims to sell about 1,000 lunchboxes for D30's a year. If the 30 is so weak, I would *think* that nobody is buying lockers for them and anybody who wants to lock 'em up is going 44 and forgetting about the 30, but obviously SOMEBODY is running a lunchbox in a 30 or Aussie wouldn't be selling them at a rate of 3 a day.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #2 of 16 Old 09-28-2013, 07:49 AM
alc60560
Is it a daily driver? I have one in mine not a DD. PM me with your number and I will let you know pros and cons. I'm local in yorkville
alc60560 is offline
post #3 of 16 Old 09-28-2013, 08:21 AM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Going on 5 years with an Aussie, no issues, Love it.
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #4 of 16 Old 09-28-2013, 08:35 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I have an Aussie in my D30 for six years now. I still have my vacuum disco, so it is totally invisible on pavement. The front driveshaft will turn constantly, but not really a problem, unless it's unbalanced. I run 35's. The only time I broke a u-joint was when I tried to back up while winching an XJ. U-joints don't like backing up under load.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #5 of 16 Old 09-28-2013, 08:52 AM
RockWoRM
RockWoRM's Avatar
I pretty much answered your Q in your other thread on lockers. On 31's or 32's your D30 is fine. It is a good axle, the only weak link being, as Ben said, are your u-joints. You have the smaller x260's. I run x760.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #6 of 16 Old 09-28-2013, 08:57 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I am debating on running one in the D30 on my XJ (Already have one in the 8.25) However if I install it it'll be in there for a few months until I regear and go selectable. Then I would transfer it into my YJ
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 16 Old 09-28-2013, 12:00 PM
davsyjdd
I have been running a Spartan for 2 years now, No problems. Did have to put a true neutral in for flat towing. It works and tows great now.
davsyjdd is offline
post #8 of 16 Old 09-28-2013, 12:09 PM
Jeffro06
Jeffro06's Avatar
I ran an Aussie in my 95 YJ with 33/12.5's....it was awesome off road. It wasn't so fun on the road in light snowy conditions, but worked great on the road in the deep stuff.
I broke one front, passenger side axle shaft, with the Aussie...but that was more driver error than anything else. I was pinned up against a rut on a downhill slope, felt like I was going to tip, tried to turn and gas it, and the bind of the wheel against the rut, the turning and the torque cause the axle shaft to give....something had to I guess.
At any rate I wheeled more obstacles with the front Aussie than I ever did without it and only ever had that one issue....I loved it.
If your D30 is a high pinion I'd keep it, unless you're going to step up above a D44.
Jeffro06 is offline
post #9 of 16 Old 09-28-2013, 07:33 PM
ROWA
ROWA's Avatar
I have a Aussie in my D30, as mentioned above absolutely invisible in 2wheel mode. Pulls hard in 4wheel mode. The D30 is a good axle for up to 35" tires.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #10 of 16 Old 09-28-2013, 07:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I've installed multiple of each brand, Aussie & Spartan in customers' Jeeps and I've never had an issue with either one.
Personally, I prefer the Spartan based solely on ease of installation.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #11 of 16 Old 09-29-2013, 01:19 AM
imstillatwork
spartan 3 or so years now. drive every day in the summer. TJ front shaft. not an issue at all.
imstillatwork is offline
post #12 of 16 Old 09-29-2013, 07:27 AM
SadDayPanda
I've installed two into buddies rigs and they have been wheeling them for a while. Liked them enough that when they upgrade they plan on using aussie again.
87, 93, 95 YJ
92, 98 XJ
87 J10
SadDayPanda is offline
post #13 of 16 Old 09-29-2013, 03:18 PM
YJames90
YJames90's Avatar
Installed 5 Aussies and everyones happy
My 2.5 to 4.3 swap thread
YJames90 is offline
post #14 of 16 Old 09-30-2013, 07:26 PM
Schaef81
Been running a spartan for months now. So far so good
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #15 of 16 Old 10-01-2013, 03:41 AM
YJames90
YJames90's Avatar
I have probably broken the ears off of 10 D30 shafts and one inner shaft. Some say its time for chromos but I just upgraded to TJ shafts and haven't had a problem yet
YJames90 is offline
