Who's runnin 2.5, ax5, 4.88s and 35"s??? - JeepForum.com
post #1 of 22 Old 10-19-2009, 06:49 PM Thread Starter
95wrangler4life
Anyone running the 2.5l with 5 speed, 488 gears and 35" tires?
Hows the performance? would you recommend the 35s or 33's?
Dont worry people, the rear is a D44 and front 30.
thanks
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #2 of 22 Old 10-20-2009, 11:57 AM
dubs27
I'm running 4:56 and 36's in mine. It has a 2.5 it runs good, but never use 5th gear and it tops out at a woping 60ish mph but I wish I had a little bigger gear but wouldent trade tire sizes. You should be fine with 35's
dubs27 is offline
post #3 of 22 Old 10-20-2009, 12:30 PM
clemsonfan16
Im running 35s with 5.13s and its great. I can run 70 easily. you should be fine with 4.88s but i would reccomend 5.13s
clemsonfan16 is offline
post #4 of 22 Old 10-20-2009, 01:13 PM
dubs27
lol..wish I had 5:13's
dubs27 is offline
post #5 of 22 Old 10-20-2009, 01:47 PM
youngYJ95
bye bye mpgs. lol. i wanna run 35's but not w/ my d35 still. i've heard that 35's are a bit much for the ax-5 however
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate]
youngYJ95 is offline
post #6 of 22 Old 10-20-2009, 06:29 PM Thread Starter
95wrangler4life
cant run 5.13 in the D30
Build thread:
post #7 of 22 Old 10-20-2009, 06:31 PM
never monday
in my TJ
it's fine
never monday is offline
post #8 of 22 Old 10-21-2009, 06:24 PM
plumber1
Don't know about 35's but my 33's are much happier with the 4:88's. I can only think that 35's & 4:88's would be about the same as my 33's were with 4:10's not great.
31's & 4:10's very drivable and fun
33's & 4:10's not much fun and SLOW
33's & 4:88's WOW MORE FUN and very drivable again
35's & 4:88's not much fun and SLOW " I Think "
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #9 of 22 Old 10-21-2009, 06:37 PM
OneCleanYj
Actually it's not bad...
Seems like performance varies from Jeep to Jeep, but I run this exact set-up without any issues. The jump from 33's to 35's was hardly noticeable for me. If anything, it was as if I had the same performance I had with my 33's with the stock TB before I added a 4.0 TB (If that makes any sense to you, lol)
Hit any longer inclines, and it slows down, but I still hold the speed limit most the time. Higher elevations kill me though...
35's with the AX5 definitely isn't the strongest set-up, but doable. Now towing the amounts of weight I have in the past, with the AX5 and 35's, probably not such a great idea
All in all, I drive the living hell out of mine and I get around fine
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #10 of 22 Old 02-01-2010, 08:47 PM Thread Starter
95wrangler4life
anyone else, im making my final decision on either 33's or 35's next week!
Build thread:
post #11 of 22 Old 02-02-2010, 05:11 AM
tranzamwayno
if you wheel it get 35's, won't get high centered as much
tranzamwayno is offline
post #12 of 22 Old 02-02-2010, 10:24 AM
1998zj
Go with the 35's. I have run both 33's and 35's and like the bigger tires better. I can still run 75 mph on flat ground in 5th gear without a big head wind.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #13 of 22 Old 02-02-2010, 10:29 AM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
35's, 5.12's 70 MPH no problem. As for the AX5 it is not the best transmission out there but I am 4 years + on this setup now.
Back Road Jeepin
BackRoadJPin is offline
post #14 of 22 Old 02-02-2010, 11:06 AM
GRN_BEAST95
im running 4.88s and 33's and i like it. Although i can only top out at 70 but anything after 60 has a bad death wobble.
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline
post #15 of 22 Old 02-02-2010, 11:32 AM
YJake
I think my 4.10 and 30's is just enough.
You guys are bananas
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
Anyone runnin re-geared Dana 35's on 33" tires? CCJ TJ Wrangler Technical Forum 47 12-05-2009 09:48 PM
New Steps--who's runnin these? Anti-bling TJ Wrangler Technical Forum 11 08-17-2007 06:14 PM
93 Runnin Hot bamato YJ Wrangler Technical Forum 32 05-17-2007 06:32 AM
I'm runnin 3.07s and 33" Nater018 YJ Wrangler Technical Forum 7 09-29-2005 06:59 PM
"belly up" skid...anyone runnin it?? OlllllllO YJ Wrangler Technical Forum 0 12-17-2003 03:46 PM
