Who's Got the 8.8 Installed Already? - JeepForum.com
post #1 of 4 Old 04-24-2002, 09:58 PM Thread Starter
YJNotDone
Just wondering if this installation would lower your lift in the rear on a spring under axle configuration due to the larger diameter axle tube.
95, 4" susp. lift, 33x12.50 ProComp M/T's, custom square tube bumpers, , energy bushings, 4.0 HO, everything stock, 1" or 2" body lift and who knows what else coming soon.
YJNotDone is offline
post #2 of 4 Old 04-25-2002, 09:06 AM
V8wrangler_idaho
hummm I didn't notice a difrence on mine when i did the convertion on my axles. If it dose change it would only be by a 1/4 inch. it all depends on how tall the spring pearches are on the axle. If the spring pearches are taller then it could effect that but I don't really think that it change the amount of lift at all
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #3 of 4 Old 04-25-2002, 10:30 AM
dreid33
Good article on the 8.8 swap if you have not seen it.
<a href="http://www.off-road.com/jeep/tech/axle/Ford8.8/97.html" target="_blank">http://www.off-road.com/jeep/tech/axle/Ford8.8/97.html</a>
Thanks!
dreid33 is offline
post #4 of 4 Old 04-25-2002, 10:51 AM
Atropine
Atropine's Avatar
Man I cant wait to get mine!!!!
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
Anyone installed a Hand Throttle WITH Cruise Controll installed also? jtice TJ Wrangler Technical Forum 29 10-03-2011 04:43 PM
anyone ever installed a v8 in their TJ? TXjeepTJ TJ Wrangler Technical Forum 9 01-04-2007 11:36 PM
BB installed!!! zworld TJ Wrangler Technical Forum 15 12-30-2006 09:40 PM
Just installed A/C horseman YJ Wrangler Technical Forum 3 09-12-2006 11:44 PM
Installed! The_One YJ Wrangler Technical Forum 2 07-11-2003 12:31 AM
