Who makes a bolt on anti-wrap bar? - JeepForum.com
post #1 of 9 Old 06-09-2010, 04:31 PM Thread Starter
YJames90
YJames90's Avatar
Who makes a bolt on anti-wrap bar?. My welding is crap and the new springs are going in Saturday
My 2.5 to 4.3 swap thread
YJames90 is offline
post #2 of 9 Old 06-09-2010, 04:44 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
nobody does.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #3 of 9 Old 06-09-2010, 08:02 PM
TSEJEEPERS
Sorry no one that I know of either.
Maybe take it somewhere to have it welded on?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 9 Old 06-09-2010, 10:42 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Not that I'm recommending this
Joe Dillard is online now
post #5 of 9 Old 06-10-2010, 04:26 AM
dodger889
Joe now that is funny.... might as well just put in blocks and weld them to the axle and frame.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 9 Old 06-10-2010, 05:25 AM
vadslram
I think Joe's solution would work fine! It wouldn't work high performance because the short control arm on the axle would put huge stresses on the connecting bolts. It should follow the spring geometry without binding anything seriously.
My 69 Mustang had bolt on ladder bars to control the axle wrap but they would put too much under the spring to get caught off road. It worked out good for me though. I was taking an offramp of the Garden State parkway when a wheel and axle passed me, I guess my bearing went bad. When I straightened out I was skiing on the ladder bar It ground down a half an inch before I could stop but it prevented ripping the crap out of my brake system that was now on display to the world.
vadslram is offline
post #7 of 9 Old 06-10-2010, 05:37 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'm mentally working up a bolt on design for an 8.8 (using the 8.8's case casting's robust vane on the right side of the nose), but I know of nothing for a D35, which I doubt you want to spend money on anyway.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #8 of 9 Old 06-10-2010, 09:21 AM Thread Starter
YJames90
YJames90's Avatar
Ahhh, so my idea isnt that crazy after all
YJames90 is offline
post #9 of 9 Old 06-10-2010, 09:29 AM
JeeperDon
JeeperDon's Avatar
No. it's very crazy. The 8.8 has unique external casting attributes that no other axle has. Here is a photo I found of a D35 and an 8.8. Notice the huge thick vane at the nose of the 8.8 case casting (bottom), with three holes in it. That panel is 1/2" thick and was the mount for a shock absorber style anti-wrap on some applications. I am dreaming up a wrap bar that bolts to that nose panel and to a 'rock ring' type diff cover in the back and the two opposing points in the wrap rotation. I've just got too many other things on my life-plate to do it now, and not really having any wrap damage for years doesn't move it up the list.
Web Admin for
RE SOA springs w/no anti-wrap bar? ChevDog1 YJ Wrangler Technical Forum 17 06-08-2010 07:32 PM
Show your anti wrap bar ctopfabber YJ Wrangler Technical Forum 18 04-25-2010 12:55 PM
best SOA anti wrap springs iwishihad1 YJ Wrangler Technical Forum 12 04-24-2010 08:09 PM
Anti Wrap Option MNKMcNeilly YJ Wrangler Technical Forum 5 07-18-2007 02:00 PM
Anti spring-wrap bar LOCKED UP YJ Wrangler Technical Forum 9 12-04-2006 10:17 PM
