who here has replaced door handles? - JeepForum.com
post #1 of 3 Old 08-16-2011, 08:42 PM Thread Starter
Anonymous6915
2009 JK Wrangler
like the title says, im in the middle of replacing one of my full steel door handles and i cannot for the life of me figure out how to put it back in witht he alligator looking thing?
iv searched but not found a clear explination on how to do this...
PLEASE HELP...
Anonymous6915 is offline
post #2 of 3 Old 08-17-2011, 02:15 PM
USMC3531
The easiest way to put the keepers back in is from the bottom. I used a pair of 90 degree needle nose pliers to get mine in. They don't fall out as long as the spring clips are in good shape. If you take a look at how they go in before you put the handle in the door, you can be sure that they are snapping into the sawteeth of the keeper. I gave up on getting them in from the top. Keep a magnet handy to fish everything you drop out of the bottom of the door. Band aids are a good idea too for the back of your hands when you are through. Nice arrangement by the Jeep engineers!
USMC3531 is offline
post #3 of 3 Old 08-17-2011, 02:40 PM
tdewit
Option 2:
The "alligator looking thing" pushes in from the top.
Remove the window outer rubber from the door.
Use needle nose plyer to position them, thin end of wedge facing down.
Roll window down complete
Use flat screwdriver and push in completely from the top.
tdewit is offline
Have any of you guys replaced your door handles Mattshot YJ Wrangler Technical Forum 3 03-10-2010 07:02 PM
Installing outer door handles, full door 2K TJ... BucJeeper TJ Wrangler Technical Forum 4 09-28-2006 07:21 PM
door handles benvh TJ Wrangler Technical Forum 4 06-30-2006 03:15 PM
door handles???? schradas YJ Wrangler Technical Forum 1 02-14-2006 08:39 AM
re: putting side door handles back in door skaboyy TJ Wrangler Technical Forum 2 05-25-2004 10:01 AM
