09-27-2007, 10:16 PM
#1
Who has made a custom dash?
Well I'm finishing my cage up over the weekend, but am leaving out the dash bar until I figure out what I want to do for a new dash. So I'm looking for inspiration, wahtever I do will need a CJ speedo I like the style and since i'm running a 300 the speedo would work again.
So pics?
09-28-2007, 03:33 AM
#2
just put the cj dash in, it will work.
09-28-2007, 05:43 AM
#4
sorry to hijack a thread but has anyone made the YJ look a little more updated like a TJ? I think that might be nice. Anyone else agree or am I crazy and should just be looking for a TJ?
09-28-2007, 06:10 AM
#5
i wouldnt do a tj dash. they are too tall. i feel short sitting in one of those and im 6'.
91 yj, 4.0, AX15, SOA, 8.8 rear, 4.88 gears, 2.5 inch springs front, m.o.r.e shackle reversal, m.o.r.e shock hoops, 3 inch springs in rear, bilstein 5150's, shock bar, m.o.r.e traction bar, lockers, m.o.r.e high steer, SYE, old school bronco cv shaft, tube fenders, 36 inch tsl's
09-28-2007, 09:09 AM
#6
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
09-28-2007, 10:53 AM
#7
Got my eye on you.....
Originally Posted by ovrlnd
here is mine. I run a 300 and it works fine with the YJ speedo.
Now that is a sweeet setup. I like how you did the close in of each dash bezel on the sides. What brand gauges did you go with???
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
09-28-2007, 12:12 PM
#8
Here is mine. Drop that bar to the top of the cowl. Even if you keep the factory dash and gauges, loose that silly 4" tall pad. The increased visibility is awesome!
oh and this cage was built inside a factory hardtop.
Gauges are Autometer Sport-Comps (cheapest elec gauges they make)
09-28-2007, 01:03 PM
#9
wow that is really pro!
09-28-2007, 09:59 PM
#10
Yes I agree on the dash bar. In another thread on here you'll see my cage is almost done but lacking a dash bar. It won't go in until later when I do a new dash. Right now the hold up is $ as with every project. The cage and new high steer has me tapped out.
09-29-2007, 06:57 AM
#11
So pics?
The only Jeep D300 that you'd have a speed sensor problem with would be the 1980 (short version) - the rear output assembly will only accept the cable type attachment. With this t-case, you need to get an interface unit that will give you the mechanical to electrical signal conversion - these are available. The simplest units are those from 1981+, the rear output assembly already has the mechanical portion that was used on the early NP231, so all you need to do is attach the NP231 speed sensor to this or take the whole sensor and speedo gear assembly & put it into the D300. If you need to change speedo gears, use the "long shaft gear" for this application (the newer NP231 cases have a different mechanical attachment that uses a short shaft gear).
09-29-2007, 09:20 AM
#12
thanks. they are equus guages. 4wd hardware carries them I got mine from JC Whitney as they are not listed by brand in the catalog and are a couple bucks cheaper.
I wanted a real basic look/vintage look. I installed the same setup in my dads jeep when we swapped motors and equus did update the typeface on the guages but still look simple.
09-29-2007, 02:42 PM
#13
executed nicely but what was the point of doing this?
09-29-2007, 02:56 PM
#14
necessity. 10 years ago when I swapped motors there were no options for yj's with aftermarket guages. I disliked the idea of using the factory plastic as a base for my new dash and only wanted to run 4 guages.
09-29-2007, 03:19 PM
#15
Well it looks really nice. Good job!
I'm hoping to eventually make my own dash like that, but all the way across.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
