Who designed this? - JeepForum.com
post #1 of 10 Old 07-13-2010, 05:29 AM Thread Starter
kstt
Who designed this?
I've got a '93 that's mostly stock, but I set it up as a plow Jeep. Sometimes, I need to pull someone out of a ditch........or I need to BE pulled out. Why in Krist's sake isn't there anything in the rear to hook a chain to?? You have to use the GD bumperette....grrrrr.
kstt is offline
post #2 of 10 Old 07-13-2010, 05:43 AM
DoctorPhate
XJ Cherokee
First, dont use those bumperettes.
Second, it wasn't designed as a tow truck but its pretty easy to add tow hooks. If you're pulling from the rear(which I wouldnt suggest) you can strengthen the rear portion of the frame then attach some D rings and pull with those.
DoctorPhate is offline
post #3 of 10 Old 07-13-2010, 06:14 AM
Roadyy
Worst case scenario buy a class III tow hitch for the back then you can buy a reciever with the d-ring attached to it strictly for pulling you/them out.
Roadyy is offline
post #4 of 10 Old 07-13-2010, 10:30 AM
dell2028
dell2028's Avatar
Get a rear bumper that has some clevis mounts.
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
post #5 of 10 Old 07-13-2010, 10:32 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Annnnnd don't use chains. Steel has the capability of storing serious amounts of elastic potential energy.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #6 of 10 Old 07-13-2010, 11:01 AM
Que89YJ
UltimatE, no tow chains? I know with winching cable was a bad idea, but no chains. I havent heard that before.
Que89YJ is offline
post #7 of 10 Old 07-13-2010, 11:13 AM
NateWithoutBeer
Straps.
Originally Posted by offshore View Post
So I totalled my 2005 Unlimited about 3 weeks ago, and now that I could find something that I really wanted I decided to go with a YJ. I loved my 04, but I wanted a real jeep
NateWithoutBeer is offline
post #8 of 10 Old 07-13-2010, 12:33 PM
muddy93
1987 FSJ Wagoneer
Originally Posted by NateWithoutBeer View Post
Straps.
And to add to that^^^^, you want a RECOVERY strap, NOT a tow strap.
Tow straps generally have hooks on the ends, you do not want to use those for recovery. Recovery straps have loops sewn into the ends, those are the kind you want to use for pulling out a stuck vehicle.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #9 of 10 Old 07-13-2010, 12:36 PM
wickedoffroad
1987 YJ Wrangler
Agree... if you are stuck using chain or tow cable always carry a heavy jacket or beach towel. placing this over the line/chain may not seem like much but I have personally see it stop the devastation that can come from snapping cables.
wickedoffroad is offline
post #10 of 10 Old 07-13-2010, 01:30 PM
AZoriginal
Here's how I solved the same problem with very little expense. Maybe $50 total in parts. I built this custom bumper out of a 5' piece of 4" x 4" angle iron. Notice the 1.5" straps underneath that are welded to the frame and bolted into the bumper and recovery hooks. This allows stress during recovery to be transferred to the frame instead of the bumper. The chrome eyes on the ends are tie downs for my canoe.
BTW, I cut off the extra on the bolts underneath after these photos were taken to save the skin on top of my head. So, don't bother suggesting I fix the obvious.
Never, Never, Never Give Up
Winston Churchill
AZoriginal is offline
Who designed the YJ? AMC or Chrysler? D-BO YJ Wrangler Technical Forum 15 02-04-2010 05:58 PM
who designed the 93 yj? propkillr YJ Wrangler Technical Forum 4 05-20-2009 08:00 AM
So what idiot designed the oil drain on these things!?! danheit TJ Wrangler Technical Forum 30 05-29-2008 02:37 PM
Anyone have BestopTireCarrier designed to be used with BL? Dan-O TJ Wrangler Technical Forum 3 05-05-2006 10:55 AM
Some pics of Jeep and New Rack I designed ascola TJ Wrangler Technical Forum 14 06-14-2004 06:23 AM
