who to buy some parts from? (timing chain set) - JeepForum.com
post #1 of 4 Old 09-10-2001, 08:00 PM Thread Starter
iamthemellowman
I'm trying to find a good price on a timing chain set (gears + chain) so far the only one i've found is cliffordperformance for $120
i mean it's not a lot but still the chain i can buy for $10
btw, this is for a '92 4.0L (242ci?)
i also need a timing cover gasket kit... not sure who has this as a 1 part number type deal for the two gaskets and seal?
I'm looking,, if i find what i'm asking about i'll share for those that might want to know as well
Thanks
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
post #2 of 4 Old 10-07-2001, 08:57 PM
B2hi
Try 4wd.com
87 Wrangler 4.2
Mopar MPI
4.0 Head
Throttle body spacer
K+N air filter
Con-ferr shackles,R.E. 4.5 lift with 33x12.5 BFG Muds and 1in. body
B2hi is offline
post #3 of 4 Old 10-08-2001, 07:29 AM
glm 87 wrangler
TRY jeepdoc.com or krage motor sports some of the lowest prices I have found.They are both the same site.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #4 of 4 Old 10-08-2001, 07:37 AM
glm 87 wrangler
Hi again Just going to give number did not see the part on web site but they should be able to get it because I did not see does not mean they dont have it. Trust me they got alot off stuff here you go ...731-926-1004
Krage motor sports.I have gotten stuff from them that was still way cheaper than auto parts store even after shipping charge I save Big Bucks
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 09:36 AM
Is this a bad Timing chain?? berg4068 YJ Wrangler Technical Forum 2 11-17-2009 06:25 AM
Can a 4.0 timing chain set be used on a 4.2? rollerized YJ Wrangler Technical Forum 5 05-15-2007 08:55 PM
Timing Chain bucko81 YJ Wrangler Technical Forum 0 09-14-2004 10:06 PM
Timing chain 93 Blue Demon YJ YJ Wrangler Technical Forum 0 03-18-2003 02:03 PM
