White "Stuff" on shifter arm? - JeepForum.com
post #1 of 7 Old 05-18-2007, 08:53 AM Thread Starter
denwagh
So I'm pulling my tranny and I removed the shift arm from the tranny.. The tip of it is coated in a white substance... Someone PLEASE tell me this doesn't mean I have water in my tranny!! I know tranny fluid isn't WHITE.. I can take a pic if needed..
It soft of looks like grease so that is possible I suppose.. Anyway!
denwagh is offline
post #2 of 7 Old 05-18-2007, 09:54 AM
jeepnmike
jeepnmike's Avatar
Does it feel and smell like grease? What does the tranny fluid look like?
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
post #3 of 7 Old 05-18-2007, 09:56 AM Thread Starter
denwagh
I plan on checking the fluid in the tranny once it's out.. I haven't taste tested the white stuff yet but will do so.. I suppose this post was un-needed but I was here and posting so...
denwagh is offline
post #4 of 7 Old 05-18-2007, 10:01 AM
zeus87gn
1987 YJ Wrangler
White Lithium Grease?
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #5 of 7 Old 05-18-2007, 10:05 AM
mp3coupe
mp3coupe's Avatar
If your pulling the tranny why not drain the fluid instead of guessing of possible water??? It would probably make less of a mess to drain it before it comes down
mp3coupe is offline
post #6 of 7 Old 05-18-2007, 10:26 AM Thread Starter
denwagh
I'm using a hoist, should be ok outside of the vehicle.. I've taken a closer look and i believe it's lithium grease..
denwagh is offline
post #7 of 7 Old 05-18-2007, 11:59 AM
1 ton yj
1 ton yj's Avatar
Yes it is.
1 ton yj is offline
2008 JK shifter knob "twist or press" P-nut JK Wrangler Technical Forum 12 07-31-2008 02:37 PM
What's the best stuff to use to "Linex" the Interior Floor? 04TJSportRed TJ Wrangler Technical Forum 4 03-03-2007 12:41 PM
White "speckles" appearing in paint BLAINE TJ Wrangler Technical Forum 8 11-28-2005 09:51 PM
Will 15x10" wheels with 3 5/8 bs stuff with 4" of lift? ryan_289 TJ Wrangler Technical Forum 3 03-02-2005 08:27 PM
"White" Marker (blinker) light covers? dan sacco TJ Wrangler Technical Forum 8 04-04-2004 09:16 AM
