white smoke out of the exhaust - JeepForum.com
post #1 of 9 Old 06-17-2012, 02:21 PM Thread Starter
Xzero117
I recently replaced the cylinder heads on my jeep(sbc 350) with new head gaskets and everything, however now there is white smoke coming out of the exhaust that smells a lot like fuel not coolant, the smoke is dry and puffy,100% sure it's not steam, coolant levels are fine and i don't know what it could be
could i be burning oil ? the smoke isn't blue but when i took off my intake to swap the heads i noticed the inside of it was covered in oil
it really smells like gas but maybe that's because i'm not running any cats
the heads have new valve seals, this is drving me nuts
Xzero117 is offline
post #2 of 9 Old 06-17-2012, 02:26 PM Thread Starter
Xzero117
forgot to mention
it did this before the head swap, but now it's been greatly amplified, i went from 76cc chambers to 58cc, so the higher compression might have something to do with it
Xzero117 is offline
post #3 of 9 Old 06-17-2012, 02:56 PM
1992 renagade
Does the oil on the dip stick smell of gas?
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications
Blue Mountain Jeep Alliance
Delaware jeep Association
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline
post #4 of 9 Old 06-17-2012, 05:52 PM Thread Starter
Xzero117
slightly,yes
Xzero117 is offline
post #5 of 9 Old 06-17-2012, 06:14 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Sounds like bad rings to me. Upping the compression made it worse.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #6 of 9 Old 06-17-2012, 07:05 PM Thread Starter
Xzero117
yeaaaaa kinda what I was thinking
i might be sucking a bit of oil through the pcv valve, i'll replace that or eliminate it and then change the oil to something thicker, i mean it's not smoking too much, just enough to annoy the hell out of me
Xzero117 is offline
post #7 of 9 Old 06-17-2012, 09:32 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
White smoke is unburnt fuel, beyond the black level you get from just running rich.
It's not just a little problem, it indicates one or more cylinders not firing. Or not getting anywhere near s complete burn.
Check compression.
ratmonkey is offline
post #8 of 9 Old 06-19-2012, 03:28 PM
1992 renagade
Originally Posted by Xzero117 View Post
slightly,yes
Is the oil level now over full? I once had a Nova with a SBC that had a bad fuel pump and was dumping raw fuel into the oil and it smoked(white smoke) like crazy.
Neill
1992 black Renegade
AtoZ Fabrications
post #9 of 9 Old 06-19-2012, 04:05 PM
Mywrangler94
white smoke...
If you have been burning oil before changing the head gasket, I wouldn't doubt that your rings are pretty much stuck also. It happens alot in 2cycle outboards and small bikes using cheap 2 stroke oil. The ring grooves fill up with unburnt oil and the rings stick closed. When I worked at the marine repair shop, we often pulled the plugs and filled the cylinders with what is called...."Power Tune". Its made specifically for this problem. You can use it on any engine, and it does work...You just have to get it at a marine supply store. I've seen it bring compression up 20 to 30lbs when allowed to sit overnight. It just allows the rings to reseat correctly. It wont solve your burning oil problem, but it will help. Hopefully alot. Its specifically made for carbon build up and stuck rings in 2 stroke engines, by those engine manufacturers. If you do use it, start your jeep in the street. What blows out the tailpipe will stain your driveway. You'll be amazed....
Mywrangler94 is offline
well my jeep went to hell. YJ windshield frame on TJ? White smoke coming from exhaust hotwheels01 TJ Wrangler Technical Forum 15 09-30-2011 01:49 AM
white smoke jjms16 TJ Wrangler Technical Forum 6 06-01-2011 06:01 AM
what does a lot of white smoke out of the exhaust mean??? twomanyjeeps YJ Wrangler Technical Forum 15 12-04-2008 07:07 PM
White Smoke!!? mcvgums JK Wrangler Technical Forum 8 04-15-2008 03:57 PM
White smoke out of exhaust AGENT YJ Wrangler Technical Forum 10 07-04-2006 08:30 PM
