Quantcast Whirrring noise in 5th...lost all but 4th gear? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Whirrring noise in 5th...lost all but 4th gear?
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 01-06-2006, 07:13 AM   #1
boatingncst8fan
This morning my Jeep started making a loud whirrring noise when I shifted into 5th (I'd noticed some whirrring when in 1st & 2nd over the last few weeks but didn't think much of it). I shifted back to 4th as I was only going 45-50 MPH and the noise went away. As I approached a red light and began to slow down, I couldn't shift into a lower gear (3rd or 2nd) as the light turned green for me. I coasted into a parking lot and could not get the transmission into any gear with the engine running. When I let the clutch out with the tranny in Neutral, it made another louder whirrring noise so I turned the engine off, put it in Reverse and restarted the engine. As I released the clutch and tried to back out of the parking space there was a terrible grinding noise.
I was able to get home using a noisy 1st gear and a smooth, probemless 4th gear...the rest would only grind when you tried to shift into those gears. I haven't had a chance to pull the drain plug to inspect for shavings yet.
Does this sound like the tranny went out? If so, what are your recommendations for repair/replacement?
Have mine rebuilt? Buy a rebuilt tranny and if so from whom? Ebay??
Great timing, as I found out yesterday my furnace is bad and will be having it replaced today.
TIA
'93 stock, not lifted, 2.5 liter, 5-speed with 59K miles riding on Yokohama Geolander AT+ II 31X10.50's, no doors and Bestop soft top
boatingncst8fan is offline   Reply With Quote
Old 01-06-2006, 10:59 AM   #2
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
Sounds like the clutch or maybe the flywheel. Maybe something came apart in the tranny and is rumbling around inside of the tranny.
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline   Reply With Quote
Old 01-06-2006, 03:22 PM   #3
kimvansa
When I lost all gears and couldn't engage anything it turned out to be a broken
5th/ reverse main cluster shaft, hoping for your sake it's not the same but be prepared and keep smilin 'cause we all know Jeeps love what's in our wallets!
kimvansa is offline   Reply With Quote
Old 01-06-2006, 03:29 PM   #4
j-man
sounds like syncros maybe
1988 Red Wrangler
2.5L 4 banger
soft top, half doors
pioneer cd deck, sony xplode speakers
cragar rims/30" continental
soon to come:
2.5 spring lift
1" body
31" tires (i like fender clearance :) )
[COLOR=Red]Red Jeep Club #297[/COLOR]
j-man is offline   Reply With Quote
Old 01-06-2006, 03:30 PM   #5
boatingncst8fan
Did you rebuild it or have it rebuilt or did you buy a reman'd one?
Oh yeah....
Old 01-08-2006, 11:46 AM   #6
psycho_emt_yj
My Yj tranny just did the exact same thing, turned out to be the synchronizers, except mine got stuck in first gear, I would just replace the tranny, changing the synchros is more trouble than its worth.
If you can't duct it, f*** it.
[COLOR="White"][SIZE="3"]WHITE JEEP CLUB MEMBER #197
[/SIZE][/COLOR][COLOR="Lime"][SIZE="3"]GEEK OFFROAD MEMBER v2.0[/SIZE][/COLOR]
[COLOR="Orange"][SIZE="3"]4-Slow 2.5L YJ Club #2[/SIZE][/COLOR]
[COLOR="red"]FF/[/COLOR][COLOR="white"]EMT/[/COLOR][COLOR="royalblue"]Police/[/COLOR]Military Jeep Club [COLOR="white"]#123[/COLOR]
Too Many Jeep Clubs Club Member#1
psycho_emt_yj is offline   Reply With Quote
Old 01-08-2006, 01:06 PM   #7
Tomb Raider
MyJKRocks!
It's a shot tranny. I just replaced mine a month ago. Same symptoms. Reason it doesnt do it in 4th....is because 4th is the only direct gear. All other gears are off the main shaft. 4th is 1:1 ratio.
If your willing to do the work, you can get reman trannies off ebay for a reasonable price. You have an AX-5 tranny for reference.
So....sorry to say...but your gonna need to do this....
Tomb Raider is offline   Reply With Quote
Old 03-09-2006, 12:04 PM   #8
miketyson
my reverse gear grinds which some say is normal, in the even that it does blow what trannys can be swapped directly and which ones are better than others in quality.. gear ratio differences and what not. whats the best and cheapest replacement tranny
miketyson is offline   Reply With Quote
Old 03-09-2006, 12:19 PM   #9
MLJeeper
MLJeeper's Avatar
common but i wouldnt say normal. It will eventually start poping out of gear. Took years before it got to that point on me though. The new reverse is smooth and no grinding whatsoever.
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Old 03-09-2006, 02:01 PM   #10
Jeep4x4nut
Yea my 5th gear makes some weird noises and has done it for a LONG time. it never has given me a problem? It sounds like a grinding noises but im not sure what it is. Any ideas?
93 YJ | 2.5L | SOA |35 MT/Rs | 8.8/30 | 4.88s | Welded rear | Lockrite Front | Cage
95 ZJ for sale | 5.2L| F>R swap | 32 SSRs | 4.10s | Lockrite rear
Jeep4x4nut is offline   Reply With Quote
Old 03-09-2006, 02:06 PM   #11
tbart16
sounds like a tranny to me, had pretty close to the same experience with my CJ. keep your eye on the 'bay for a tranny good luck
Tom
'95 F350 Powerstroke Crew Cab Dually
'04 RX 330
'97 lumina ex-cop car
'98 TJ 4.0 auto lots of goodies
tbart16 is offline   Reply With Quote
Old 05-17-2009, 10:04 PM   #12
BuckeyeTJ
Great thread, never thought i would find someone that had the same symptoms i was running with, just wish the outcome wouldn't be digging so deep
J.E.E.P. or Just Empty Every Pocket
[COLOR="black"]97 TJ
2.5L 5 speed
[B]Member of:
[URL="http://www.southernohiojeepers.com"]Southern Ohio Jeepers Association[/URL]
[COLOR="Black"]Black Jeep Society Member[/COLOR]
[COLOR="Navy"]USN Jeep Club Hull #78[/COLOR][/B][/COLOR]
BuckeyeTJ is offline   Reply With Quote
Glock Forum
