whirring noise when on the gas - JeepForum.com
post #1 of 41 Old 03-04-2013, 07:41 PM Thread Starter
94YjCanz
i dont know whats going on but everytime im on the gas theres a wierd whirring noise that gets louder the faster i go, but it only makes noise when im on the gas. i dont know what it could be, but it started around the same time that i noticed the passenger rear shaft seal was leaking. i replaced that (headache in itself, it was my first time messing with anything inside the rear diff, so lets just say it took a lot longer than it should have. i had to pull the entire assembly twice.) finally got everything back together and working fine. but still makes noise. not sure what it is.
Please help?
94YjCanz is offline
post #2 of 41 Old 03-04-2013, 07:44 PM
jeepyjLeD
Does rpm have anything to do with it. If so it might be a bad bearing in the belt loop.
jeepyjLeD is offline
post #3 of 41 Old 03-04-2013, 07:50 PM Thread Starter
94YjCanz
not RPMs just speed. like in nuetral, no noise when i get on road it just gets louder the faster i go.
94YjCanz is offline
post #4 of 41 Old 03-05-2013, 07:42 AM
jeepyjLeD
Can you tell were the noise is coming from. Front,right under you, or rear
post #5 of 41 Old 03-05-2013, 07:46 AM
lakeobum
Check your wheel bearings.
lakeobum is offline
post #6 of 41 Old 03-05-2013, 08:41 AM
Flajeeper1
1987 YJ Wrangler
Start by identifying where the noise is coming from. Also check your diff fluid while you're at it.
Flajeeper1 is offline
post #7 of 41 Old 03-05-2013, 08:04 PM Thread Starter
94YjCanz
it sounds like its either right under me or just behind me. also, checked and changed wheel bearing and seals in rear (had a wet right side, figured i knock out both while i was in there.) i know diff fluid is where it needs to be. as of right now i have the drive shaft off the back, trying to get the u joints out to change them. still dont know where to take them to get the old ones pressed out. i have a puller and tried using that with absolutley no luck
94YjCanz is offline
post #8 of 41 Old 03-05-2013, 08:21 PM
pasinbuy
If it is just when you press the gas are you hearing the air rush into the intake?
I hear it on my 94.
pasinbuy is offline
post #9 of 41 Old 03-05-2013, 08:48 PM
jeepyjLeD
Just wondering did you take out the retainer clips. And you can use a hammer and a socket smaller then the eye of the shaft. spray somepb blaster and hit it out just be careful not to bend the eyes.
post #10 of 41 Old 03-05-2013, 08:54 PM
jeepyjLeD
For my jeep I had a knocking ,grinding sound from my tcase. It was the chain slapping the side of the case because the chain was warn out. You could try to run the jeep without the rear shaft just to see if its something in the rear axle. I would only do that as a final straw to this problem.
post #11 of 41 Old 03-07-2013, 10:48 AM Thread Starter
94YjCanz
Got the u joints changed, no fix. Can't say I'm not surprised. Let me explain the noise a lil different bc I don't think everyone is gettin the full idea. It's kinda like the sound that a train makes on the tracks or how a roller coaster sounds on the first hill, minus the screams or train engine. I've been hoping its not the t-case, but running out of hope. Something that is put under load is rubbing and I'm fresh out of any more thoughts.
94YjCanz is offline
post #12 of 41 Old 03-07-2013, 11:41 AM
BGarth13
From left field: speedometer cable?
BGarth13 is offline
post #13 of 41 Old 03-07-2013, 11:53 AM Thread Starter
94YjCanz
Care to explain
94YjCanz is offline
post #14 of 41 Old 03-07-2013, 01:02 PM
jeepyjLeD
There is no speedo cable on the 94s it electronic still has a gear in the tail housing of the tcase
post #15 of 41 Old 03-08-2013, 04:26 PM Thread Starter
94YjCanz
I'm gonna pull the t case and poke around in there for a few, check the chain and such
94YjCanz is offline
