Whining/Whirring Engine Noise - Page 3 - JeepForum.com
post #31 of 37 Old 09-13-2013, 06:36 PM Thread Starter
DustyGeneral
Just want to let you guys know who have been helping me (if you even care haha), I swapped the 90 amp for a 136 amp alternator. Worked like a freakin' champ. Voltage drop with all of the lights is minimal (didn't test with winch) and she purrs like a kitten. If the alternator craps out I will switch her out, though I'm not thinking it will since the quality of the rebuilt parts from the local advance has always been good. Thanks guys for your input!
DustyGeneral is offline
post #32 of 37 Old 09-13-2013, 07:08 PM
SeanB95YJ
When you can, remove the charging wire (the 6 or 8 ga wire coming from the alt to the PDC) and remove the 2 50 amp alt fuses from the PDC...
then get yourself a piece of 4 or 2 ga battery cable and run that from the alternator directly to the pos. terminal of the battery.... while you're at the auto store getting the piece of battery cable to do this, also pick up a 150 amp mega fuse... put that somewhere in the line.
now your system will charge better (heavier wire capable of handling the higher current of the bigger alt) and the system will be protected from possible over-charging - the wiring/fusing of the PDC is only wired for a 100 amp alt (for your formerly stock 90 amp alt)... you're now capable of 136 amps + or - so the 150 amp mega fuse will protect
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #33 of 37 Old 09-13-2013, 07:22 PM
Que89YJ
That is great news! You have to love an off the shelf upgrade.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #34 of 37 Old 09-13-2013, 09:48 PM
Gage56
WOOT
Glad i could help ya out
1992 YJ
Gage56 is offline
post #35 of 37 Old 09-24-2013, 04:58 AM
SPYDERYJ
1987 YJ Wrangler
Glad to see that your issue got fixed. Wish mine was that simple. Now it's been narrowed down to either the crankshaft or camshaft bearings.
1987 YJ with 6" shackle lift on 33x12.50R15's.
SPYDERYJ is offline
post #36 of 37 Old 09-30-2013, 11:23 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Looking for the NAPA reman part number for the 136 amp alt. anyone have it handy? Found the Dodge Durango 160 amp alternator number but not the 136.
Posted via my pretentious iPhone.
EDIT: Nvrmnd found it OEM PN: 56027913
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #37 of 37 Old 10-01-2013, 03:24 PM
Siva283
I did the Alt upgrade. I upgraded the pos and neg wire as well. Then I installed a rediculously big battery to run the winch. Then a year later I spent two days on the phone with Que running down an electrical issue. The issue would have never came about if I would have fused the POS wire. Learn from my mistake put in a fuse with the upgraded wiring it will save alot of headaches. In the end it fried a head unit killed the alt and shorted the battery.
Ask me how I know...
Siva283 is offline
