Whining noise when driving - JeepForum.com
post #1 of 3 Old 02-21-2012, 09:34 PM Thread Starter
deathstar
I know that this is going to sound wierd but whenever I give it gas it sounds like a whirring/whining noise when I let off it whines but skips and whines at the same time like neh neh neeehhhhhh. Sorry if this sounds funny but Im not mechanically inclined with cars and trucks. Thanks in advance.
deathstar is offline
post #2 of 3 Old 02-21-2012, 09:57 PM
4x4JB
Could be a number of things. Could be alternator or some sort of vacuum leak. I had loose exaust manifold bolts that made it whine. Try and pin point it to a location. Open your hood with the engine running and give it gas by turning the lever your cable links to on your throttle body(it's the thing that goes from your gas pedal to the engine). Once you pin point the location people can help you a little more. Check all your fluids(power steering mainly) also.
Last edited by 4x4JB; 02-21-2012 at 09:59 PM. Reason: Damn iPhone auto correct....
4x4JB is offline
post #3 of 3 Old 02-21-2012, 10:35 PM Thread Starter
deathstar
Will do but it sounds like its coming from the back would low oil in the differential cause it
Whining Noise while driving andypohlman TJ Wrangler Technical Forum 18 01-22-2008 08:44 PM
jeep making whining sound while driving jkenn72 TJ Wrangler Technical Forum 1 10-10-2007 10:26 PM
Whining noise davido TJ Wrangler Technical Forum 6 02-28-2007 09:44 AM
Whining Noise... okstateAlum TJ Wrangler Technical Forum 6 11-27-2006 04:08 PM
Whining noise when wet JeepMax YJ Wrangler Technical Forum 1 01-03-2003 12:09 PM
