While I have the Radiator off..... - JeepForum.com
post #1 of 7 Old 10-03-2013, 08:13 AM Thread Starter
Ruke400
Guys-
I am in the middle of replacing the Radiator on my 4.2. While I have that and the fan shroud off, what else should I work on?
The jeep is not moving anytime soon while I work on a new cj style dash.
Its a 1990 with 150k miles. Water pump? Thermostat? Belts?
Thanks.
-Ruke
90 Wrangler- Nuttered 4.2
Auto Trans, Stock Axles
Ruke400 is offline
post #2 of 7 Old 10-03-2013, 08:29 AM
Que89YJ
Look at the ford taurus electric fan mod, upgrade the alternator to the cs-144, normal maintenance for wear parts like the thermostat, belts, water pump, hoses, etc.
You might want to consider the nutter Bypass, Team Rush mods too.
Que89YJ is offline
post #3 of 7 Old 10-03-2013, 08:46 AM Thread Starter
Ruke400
Already Nuttered. Put a MC2100 from the ebay guy on last year.
Does the alternator swap work with the radiator in? I may wait until the current alt dies.
-Ruke
Ruke400 is offline
post #4 of 7 Old 10-03-2013, 08:52 AM
Old4X
1990 CJ7
Check your timing chain for slack. Much over 6 degrees at the crankshaft is time to replace chain and both gears.
The OEM cooling system is near bullet proof, stay with it by using a good radiator, OEM pump, shroud, fan , fan clutch and thermostat.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 7 Old 10-03-2013, 08:57 AM
jbolty
jbolty's Avatar
definitely flush the cooling system, including the heater core. Belts, hoses and water pump are all pretty cheap and it's nice to know everything is in good working order.
jbolty is offline
post #6 of 7 Old 10-03-2013, 08:59 AM
dancytron
Upgrade the electrical.
Bigger battery cables. I went with 1 gauge welding cable for the starter and main grounds and 4 gauge for the 8 gauge wire running to the starter relay.
"Big 3 upgrade." This is an upgrade that kids with obnoxious stereos do. Right now, the link between the alternator and the battery is a 8 gauge wire that goes through the starter relay, a fusible link, and then a 10 gauge wire to the alternator. This is a weak point. Bypassing that and grounding the alternator and chassis better are the "Big 3"
Dedicated grounds. Best thing I did. If I had to go completely back to like it was when I bought it except one thing, I'd keep the dedicated grounds. Silly electrical problems just went away and when I do have an electrical problem, I know it isn't the grounds. http://www.jeepforum.com/forum/f8/be...1/#post7724128
Fuse for big 3 upgrade - http://www.donrowe.com/accessories/fuse_anl.html
Replace every hose (vacuum or otherwise) that looks like it was original with the jeep.
dancytron is online now
post #7 of 7 Old 12-23-2013, 08:17 AM
fishadventure
Originally Posted by Ruke400 View Post
...While I have that and the fan shroud off, what else should I work on? The jeep is not moving anytime soon while I work on a new cj style dash....Its a 1990 with 150k miles. Water pump? Thermostat? Belts?
Belts and thermostat are a good idea if they are unknown age or belt looks bad. I wouldn't replace anything else unless they look old/worn/cracked or otherwise 'bad'.
However, I would like to see pics of the CJ dash
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline
