wheres the fuel pressure regulator on a 91 jeep wrangler 4.0 - JeepForum.com
post #1 of 15 Old 04-18-2011, 10:51 PM Thread Starter
omy332
where the fuel pressure regulator on a 91 jeep wrangler 4.0. my jeep wont start and from some suggestions i think its either the fuel pressure regulator or the fuel pump. can the fuel pressure regulator be swapped for a new one or do i have installe both the regulator and fuel pump.
omy332 is offline
post #2 of 15 Old 04-18-2011, 10:53 PM
lclark2074
the regulater has a vacume line connected to on the fuel rail
night crew 226
lclark2074 is offline
post #3 of 15 Old 04-18-2011, 10:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, at the end of the fuel rail nearest the radiator.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 15 Old 04-18-2011, 11:00 PM
lclark2074
max your slowing down no pics yet
night crew 226
post #5 of 15 Old 04-18-2011, 11:03 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
LoL! These dam cellphones!!!!
Max
Mean Max is offline
post #6 of 15 Old 04-18-2011, 11:15 PM Thread Starter
omy332
thanks
omy332 is offline
post #7 of 15 Old 04-19-2011, 06:24 PM
Newk76
I think this is the same thing we just had to replace... the elbow coming from the end of the fuel rail to the rigid tubing was deteriorated & cracked something aweful. Here is a pic
Am I right?
Newk76 is offline
post #8 of 15 Old 04-19-2011, 06:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes you are right! That is indeed the FPR (fuel pressure regulator) in your pic.
Max
Mean Max is offline
post #9 of 15 Old 07-01-2013, 11:43 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
any special trick to remove and replace w/ new unit? Am ready to do that and have the part.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #10 of 15 Old 05-05-2014, 09:44 PM
heepyj
I'm about to change my FPR on 93 YJ 2.5...Any tips?
heepyj is offline
post #11 of 15 Old 07-09-2014, 08:56 AM
bluexj
Need to Change mine too. Any tips before I do this?
bluexj is offline
post #12 of 15 Old 07-09-2014, 09:09 AM
Que89YJ
On a XJ? The FPR is in the tank on the pump.
Que89YJ is offline
post #13 of 15 Old 07-09-2014, 09:14 AM
bluexj
I have a 91 YJ too. I should have clarified.
bluexj is offline
post #14 of 15 Old 07-09-2014, 10:09 AM
Que89YJ
It takes 10 minutes. Relieve the fuel pressure by pushing the valve on the rail. remove the vacuum line. Take out the mounting bolt. remove the old one, put the new one in. Tighten bolt and put the vacuum line back on.
Que89YJ is offline
post #15 of 15 Old 07-09-2014, 10:30 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Removed mine from fuel rail and discovered it was pretty clogged with little bits of black rubber. Uh oh... Ordered a new one from hesco and oops, did not seat properly. Seems my fuel rail accepts an older style fpr with a straight neck, not the newer one with a molded ring along the base. Hesco sent another one, same problem. Ended up giving to a buddy. Had to special order the correct unit from dodge dealer, ugh $$.
Replaced all fuel lines and she runs better than ever. Added an in line spin on fuel filter making filter changes a breeze
Now to resolve cold start issues and crank to cam correlation fault... It's always something
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
How do I replace a fuel pressure regulator in jeep? CrawlerYJ YJ Wrangler Technical Forum 5 12-06-2013 07:51 AM
fuel pressure regulator Gubni TJ Wrangler Technical Forum 3 12-18-2010 05:49 PM
Fuel Pressure Regulator - Do we have one?! bawlnchayn YJ Wrangler Technical Forum 12 12-15-2010 11:16 AM
Fuel pressure regulator 95YJI6 YJ Wrangler Technical Forum 10 04-23-2010 08:28 AM
Fuel Pressure Regulator Jeepfan Jeff YJ Wrangler Technical Forum 1 04-23-2005 08:15 AM
