-   -   wheres the fuel pressure regulator on a 91 jeep wrangler 4.0 (http://www.jeepforum.com/forum/f12/wheres-fuel-pressure-regulator-91-jeep-wrangler-4-0-a-1198259/)
omy332 04-18-2011 11:51 PM
where the fuel pressure regulator on a 91 jeep wrangler 4.0. my jeep wont start and from some suggestions i think its either the fuel pressure regulator or the fuel pump. can the fuel pressure regulator be swapped for a new one or do i have installe both the regulator and fuel pump.
lclark2074 04-18-2011 11:53 PM
the regulater has a vacume line connected to on the fuel rail
Mean Max 04-18-2011 11:55 PM
Yep, at the end of the fuel rail nearest the radiator.
Max
Sent from my HTC Incredible Droid
lclark2074 04-19-2011 12:00 AM
max your slowing down no pics yet
Mean Max 04-19-2011 12:03 AM
LoL! These dam cellphones!!!!
Max
omy332 04-19-2011 12:15 AM
thanks
Newk76 04-19-2011 07:24 PM
I think this is the same thing we just had to replace... the elbow coming from the end of the fuel rail to the rigid tubing was deteriorated & cracked something aweful. Here is a pic
http://i843.photobucket.com/albums/z...p/0039d443.jpg
Am I right?
Mean Max 04-19-2011 07:41 PM
Yes you are right! That is indeed the FPR (fuel pressure regulator) in your pic.
Max
RARECJ8 07-01-2013 12:43 PM
any special trick to remove and replace w/ new unit? Am ready to do that and have the part.
heepyj 05-05-2014 10:44 PM
I'm about to change my FPR on 93 YJ 2.5...Any tips?
bluexj 07-09-2014 09:56 AM
Need to Change mine too. Any tips before I do this?
Que89YJ 07-09-2014 10:09 AM
On a XJ? The FPR is in the tank on the pump.
bluexj 07-09-2014 10:14 AM
I have a 91 YJ too. I should have clarified.
Que89YJ 07-09-2014 11:09 AM
It takes 10 minutes. Relieve the fuel pressure by pushing the valve on the rail. remove the vacuum line. Take out the mounting bolt. remove the old one, put the new one in. Tighten bolt and put the vacuum line back on.
RARECJ8 07-09-2014 11:30 AM
Removed mine from fuel rail and discovered it was pretty clogged with little bits of black rubber. Uh oh... Ordered a new one from hesco and oops, did not seat properly. Seems my fuel rail accepts an older style fpr with a straight neck, not the newer one with a molded ring along the base. Hesco sent another one, same problem. Ended up giving to a buddy. Had to special order the correct unit from dodge dealer, ugh $$.
Replaced all fuel lines and she runs better than ever. Added an in line spin on fuel filter making filter changes a breeze
Now to resolve cold start issues and crank to cam correlation fault... It's always something
The time now is 02:32 PM.
