Where to start intermittent cut out - Page 4 - JeepForum.com
post #46 of 55 Old 08-08-2011, 01:36 PM
clush
I was gonna ask about the fuel pressure situation too. It almost has to be a fuel delivery problem from the sound of it. Good luck man, thanks for getting back to let everyone know what's up.
clush is offline
post #47 of 55 Old 08-09-2011, 09:37 AM Thread Starter
bchap05
Now that I've got the body lift done and fixed the steering noise yesterday, I'll be renting the pressure gauge again tonight and seeing if it drops at all with the hoses not smashed. I took the Jeep for a drive Sunday to try and make it do it so I could try a few things and it refused to do it. It was about 100 degrees out and I drove farther than I normally have to in order to get it to act up. So once I get the gauge on tonight hopefully it will act up or just stop all together.
bchap05 is offline
post #48 of 55 Old 08-09-2011, 11:46 AM
Que89YJ
The only thing I am afraid of is that when that return line gets blocked for whatever reason and its run for any length of time something eventually gives; either the regulator or the pump itself. Keep us posted.
Que89YJ is online now
post #49 of 55 Old 08-09-2011, 08:28 PM Thread Starter
bchap05
I think your right Que89yj, I finally got somewhere tonight. I was able to get the hood closed with the gauge working finally by stuffing towels on both sides of the hose and then closing it. I didn't have the gauge really close to the window so I couldn't get the exact number while driving but psi was somewhere around 38 holding steady. I finally feel the jeep cut and immediately the gauge starts jumping. Not very far at this point but it basically looks like someone is shaking it. It starts cutting worse and the pressure drops to 10 and then 0 as it cuts completely. I let off the gas it goes back to 10 and then back to 0 as I gas it and it cuts more.
So I'm thinking the return line got smashed causing high pressure and also killing the pump in the process. I lifted it getting the pressure back to where it should be but the pump was already dead from the high pressure. Now the issue is from what I've seen on here in a brief search and also talking to a Jeep mechanic is finding the right pump as there are a bunch of different ones for jeeps.
bchap05 is offline
post #50 of 55 Old 08-10-2011, 05:47 PM
clush
Well at least it seems like you are starting to narrow it down more!!
clush is offline
post #51 of 55 Old 08-10-2011, 06:17 PM
zman
A mechanic friend of mine says he will only replace fuel pumps with OEM ones. He had to many problems with knock off pumps and when you have to pull the tank to fix it a second time, well, don't go cheap when alot of labor is involved.
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
post #52 of 55 Old 08-11-2011, 10:10 AM Thread Starter
bchap05
I'm planning on either the Bosch or Delphi. Everyplace I've checked with locally either carries Bosch or Airtex. I know Bosch was stock for awhile but I think in 94-95 it was something different? I know a Jeep mechanic who has owned a Jeep shop for 25 years and he said good look getting the right part. He said about half the time you order one and drop the tank you find out it is the wrong one.
bchap05 is offline
post #53 of 55 Old 08-11-2011, 10:15 AM
oldtime_ironman
My local NAPA guy came up with a big beefy Carter brand to replace the Bosch - I could recommend either one.
NAPA part number PA74155
oldtime_ironman is offline
post #54 of 55 Old 09-03-2011, 05:33 PM Thread Starter
bchap05
So I finally got around to changing the fuel pump. Bought a Bosch from NAPA it looks identical to the factory but the part number was slightly different. Pretty easy job I cut the floor instead of lowering the tank. Took about 10 minutes to cut the floor and have old pump out. Whole job would have probably taken an hour or less but I put everything back together and the jeep wouldn't start. Had to take it back apart and the ground on the new pump wasn't hooked up. Took a 40 minute drive at 65 including going up hill with no problems, I think its fixed.
bchap05 is offline
post #55 of 55 Old 09-04-2011, 04:07 PM
jeepster11
My 92 had an intermittent stall...I had a bad distributor coil. Grounding the coil showed weak and intermittent spark.
jeepster11 is offline
intermittent rough start? blue04jeep TJ Wrangler Technical Forum 22 05-01-2011 06:12 AM
Intermittent Start Issue thedirt TJ Wrangler Technical Forum 7 04-22-2010 02:13 PM
intermittent no start/surge baddkarmaracing YJ Wrangler Technical Forum 6 02-24-2010 03:46 AM
99 Wrangler intermittent start when hot ajmjbrowning TJ Wrangler Technical Forum 2 11-13-2008 09:36 PM
intermittent no start catch YJ Wrangler Technical Forum 4 07-28-2005 08:46 PM
