where is my temp sensor - JeepForum.com
post #1 of 3 Old 06-29-2013, 03:32 PM Thread Starter
felix1234567890
I recently took my 90 yj and installed a brand new motorcraft carb. now i am not getting any reading from my temperature gauge. both sensors on the side of the intake manifold are in good shape still but the sensor on top of the manifold right in front of the carb was broken. i looked online to find a replacement but could only find the temp sensor on the side of the manifold, not on top. Is the broken sensor my problem and what is it. Where can i find a replacement.. trying to upload a photo
felix1234567890 is offline
post #2 of 3 Old 06-29-2013, 04:50 PM
Old4X
1990 CJ7
It is installed vertically in the head, driver side near firewall
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 3 Old 06-29-2013, 04:53 PM
pete1991YJ
Welcome t JeepForum, you've just found one of the best jeep sites anywhere!
Far as I know jeep uses 2 temp sensors, one for the engine and the other for the gauge. The sensor for the gauge should be near the back of the head on the driver's side, right near where the manifold bolts on. Purple wire on it if I recall correctly. You might also check to see the gauges have a good ground, bad grounds a very common prob. Hope that helps!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
intake sensors , motorcraft , temperature gauge
