Where is the manual transmission fill hole? - JeepForum.com
post #1 of 10 Old 01-08-2007, 05:09 PM Thread Starter
Ryanjeeper
im in the process of changing gear oil and i cant find the fill hole, i really am i noob when it comes to cars so if you could describe it to me and pictures would be great. Like is it located under the vehicle or is it best to go in from under the hood?
thanks ryan
1990 YJ
Rubicon Express 2.5" Standard Lift
32x11.50 Lemans A/T
Ryanjeeper is offline
post #2 of 10 Old 01-08-2007, 05:14 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Automatic or manual?
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 10 Old 01-08-2007, 05:16 PM Thread Starter
Ryanjeeper
manual transmission
1990 YJ
32x11.50 Lemans A/T
post #4 of 10 Old 01-08-2007, 05:20 PM
rustywrangler
The manual transmission fill plug is mounted high on the passenger's side of the case. You will need a hand pump to add oil to it. I do not have a picture of unfortunatly.
It will be under the veichle next to the muffler pipe towards the back of the tranny
I added a pic i found online. I circled the fill plug
post #5 of 10 Old 01-08-2007, 06:42 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Didn't the 90 have a BA-10/5? If so the fill is on the pass sidem just inside the skid plate.
I it's an AX-15 it's on the drivers side about the same place.
- Ernie
Richmond88yj is offline
post #6 of 10 Old 01-08-2007, 06:46 PM
MAX_Xj
MAX_Xj's Avatar
Ohio Yj has a big write up on it at the quadratec forums heres a link hope it helps.
http://bbb.quadratec.com/cgi-bin/ult...c;f=4;t=000647
1998 4dr XJ
MAX_Xj is offline
post #7 of 10 Old 01-08-2007, 06:51 PM
Low_2_Lifted
underneath!!
Yeah just did this a few months back myself... the manual filler hole is easier to reach underneath... ther is a filler hole on the drivers side and a drian hole on the passenger side... once you are under there you should see them pretty easily... if you can get a hold of one i'd suggest getting a fluids hand pump (10-15$) makes the job a lot less messy...
Low_2_Lifted is offline
post #8 of 10 Old 01-08-2007, 08:14 PM
kloppk
He got neither. He's sporting a 1990 4 cyl so it's the AX-5.
kloppk is offline
post #9 of 10 Old 01-08-2007, 10:17 PM
OhioYJ
I've got a writeup here, with pictures.
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things.
-- Mike
OhioYJ is offline
post #10 of 10 Old 01-08-2007, 10:34 PM
OneCleanYj
Originally Posted by OhioYJ
Very nice write up, bookmarked for future reference
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
Changing Manual Transmission Fluid through fill hole? BrettDez JK Wrangler Technical Forum 11 09-08-2009 03:18 AM
Manual Transmission Fill Hole - HELP!!! younts22 TJ Wrangler Technical Forum 13 05-13-2008 08:54 PM
Transmission Fill hole? austineo TJ Wrangler Technical Forum 12 02-17-2007 12:34 PM
95 2.5 manual transmission fill plug mrsneelock YJ Wrangler Technical Forum 2 12-02-2006 08:33 AM
Manual Transmission drain/fill plugs Pinebarrensboy TJ Wrangler Technical Forum 4 01-03-2004 04:48 PM
