where to get a bds springs - JeepForum.com
post #1 of 13 Old 08-14-2011, 08:04 PM Thread Starter
smoan
im looking to buy bds 3 1/2 inch springs just by them selves. Im looking to piece together a lift. thanks
smoan is offline
post #2 of 13 Old 08-14-2011, 08:08 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Go online to the site and look through their catalog and order from the section where you can order by part number. Then go and have it shipped to your local dealer. DO NOT go to your dealer and have them order it for you! You WILL be charged tax and shipping if the order is under $1000 (for the dealer).
Enjoy your springs!
Luck Favours The Prepared
Anticanman is offline
post #3 of 13 Old 08-14-2011, 08:08 PM
MJMPC
You need to fill out your jeep info.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 13 Old 08-15-2011, 10:33 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
BDS has an online 10% discount until the 25th. Here is a link to that thread. Look for post 72 for the new code.
http://www.jeepforum.com/forum/f43/b...29/index5.html
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #5 of 13 Old 08-16-2011, 06:42 AM
leadsled01
I bought BDS springs from my local distributor. No shipping but I did have to pay the tax.
leadsled01 is offline
post #6 of 13 Old 08-16-2011, 08:20 AM
acat
Supplee 4wd in okc. Got me a great price. See where ur closest distributed is and he can ship it there. Great guy to deal with.
acat is offline
post #7 of 13 Old 08-16-2011, 10:04 AM
92 Green YJ
92 Green YJ's Avatar
Head over to vendor display. BDS is a vendor here.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #8 of 13 Old 08-16-2011, 07:06 PM
timatoe
timatoe's Avatar
Bob is a super great guy and if you don't have a local dealer/distributor 100% he'll take care of you.
timatoe is offline
post #9 of 13 Old 08-17-2011, 04:40 AM Thread Starter
smoan
thanks for all of the input. I do have a local dealer Tillman's truck center, but i was just going to buy them off of bds website and they can get all 4 springs to me for 470 and that includes the bushings. Do u think bob can beat that price. and what do you think of skyjacker hydro 7000s because those are the shocks im thinking about buying. i was going to get a pittman arm of a zj. I dont have a sway bar right now so with the extra lift should i put it back on and get disconnects. i already have ss +4 lines from crown because i broke one and i figured i was going to get a lift so i bought those. i also already had 1 in lift shackles too. i also am going to take of the track bars. i got new u bolts and the axle shims and a t case drop. I will most likely get the slip yoke cv combo later down the road,
smoan is offline
post #10 of 13 Old 08-17-2011, 11:18 AM
acat
Call bob and find out. He'll give ya a price right away. I don't remember what shocks I got but there BDS brand. I haven't put my stabilizer back on after the lift and it seems to drive fine. I went with a tie rod end flip instead of pitman arm. I may eventually put the stab back on if I find a good way to mount it. I didn't put my sway bar back on and removed track bars as well. The springs will come with 4 or 6 degree shims. The front springs r heavier duty and u can just buy 4 front ones which most people seem to recommend, myself included. I didn't need a SYE/CV shaft with my 2.5 inch RC lift but with the 3.5 BDS lift and .5 inch shackles I did. I'd assume u will as well. Even with a TCD I was leaking fluid out of TC output and had a lot of play in the driveshaft (input shaft was barely in TC). PM me if you need bobs number, I'm guessing he'll beat most prices.
acat is offline
post #11 of 13 Old 08-17-2011, 11:53 AM
dtn8tr
I installed a pair in June with my OME 2.5" lift and .75" boomerang shackles and I have no complaints about them. Get them from the Skyjacker website though, under the pulldown that says scratch and dent. Nothing at all wrong with them and they were only $25 each. You can get the 8000s series for $29 each from there also.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #12 of 13 Old 08-17-2011, 01:12 PM
timatoe
timatoe's Avatar
.... Do u think bob can beat that price. ....
I agree, just give him a call and see (405) 799-8977. He doesn't keep a stock of them so they'll likely just be drop shipped from BDS. I got all four of my 2" BDS springs for under $400 to the door, so you may already be getting a good price. But, I'm cheap so I'd still call.
timatoe is offline
post #13 of 13 Old 08-18-2011, 12:44 PM Thread Starter
smoan
i called he gave me 510 for all four and bushings nice guy though it was just because of shipping i think.
smoan is offline
Cheapest 3" lift springs for front? (flexy springs) 05TurboS2K TJ Wrangler Technical Forum 22 03-18-2011 11:42 PM
OME Springs - Swapping drivers/passenger side springs? ChrisTJCO TJ Wrangler Technical Forum 27 10-09-2010 10:04 PM
Rubi springs VS stock Sport springs seekrtruth TJ Wrangler Technical Forum 12 08-22-2009 08:58 AM
How do lifts perform? BB/ZJ springs/Lift Springs? TJ_ITmgr TJ Wrangler Technical Forum 3 10-27-2007 01:14 AM
Comparing XJ Springs to YJ Springs - Height Question Big-n-Broke-YJ YJ Wrangler Technical Forum 16 03-11-2007 01:56 PM
