where did it go? - JeepForum.com
post #1 of 11 Old 01-21-2013, 12:28 PM Thread Starter
ejeeperguy
1982 CJ7
where did it go?
So I was on my way home from work and felt a big bang under my 90 YJ.When I finally found what made the noise. I was shocked, seems my rear driveshaft no longer is under my Jeep. Looked all over the street for it.No where to be found.On further inspection the slip yok snapped off and the u joint at the axle let go.I had no indication that I was having a u joint issue just let go.lucky for me is that the transfer case housing is not damaged or the yok at the axle.now trying to find those pieces are becoming a problem.
All I got to say is luckily I was not on the highway when this happened.
ejeeperguy is offline
post #2 of 11 Old 01-21-2013, 12:47 PM
Beachcruiser
1987 YJ Wrangler
You should be able to find those parts easily on Eaby....and I think there's a Jeep guy in Mass who parts out vehicles, too.
probably out breaking stuff.
Beachcruiser is offline
post #3 of 11 Old 01-21-2013, 03:31 PM
Louie4
Make sure you don't drive it around with an empty t-case. Once the slip yoke comes out on a stock NP231 the fluid will dump out (unless you have an SYE).
I'd check craigslist as most folks go for an SYE.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #4 of 11 Old 01-21-2013, 03:46 PM
Mark05059
if you HAVE to drive it you can cut the bottom off of a soda bottle and duct tape it in place.. be sure to check the fluid level before you drive it any further.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 11 Old 01-21-2013, 04:21 PM Thread Starter
ejeeperguy
1982 CJ7
No I don't have to drive till I get the parts .I bid on one from ebay .The shaft of the slip yok was still there so I didn't lose much fluid out the back of the t-case.Don't you know that it just started to snow on top of it all.
post #6 of 11 Old 01-21-2013, 04:50 PM
NonRubicon
Sounds like what mine did, although I hadn't been going fast so the driveshaft remained attached to the rear axle yoke. Makes a big BANG! indeed.
I hope your slip yoke isn't wedged in the housing like mine was after it went boom. For myself, it was a PITA to remove the tail cone housing with the slip yoke sleeve wedged in it.
NonRubicon is offline
post #7 of 11 Old 01-21-2013, 05:26 PM
uhohthe50
I recently put a SYE on my jeep and still have my stock rear ds. Send me a pm with an offer if you are interested.
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline
post #8 of 11 Old 01-22-2013, 02:30 PM Thread Starter
ejeeperguy
1982 CJ7
I can get the rest of the slip yok shaft out. Right now it is holding the fluid in from leaking out.I have a bid on one from ebay so waiting to see if I get that one.
post #9 of 11 Old 01-22-2013, 02:50 PM
YJ4LIFE
fyi there are many different driveshaft lengths for our jeeps.. I had my old one that needed repalcing due to u joint failure and it was still hard to find a match at a large jeep junkyard.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #10 of 11 Old 01-23-2013, 06:08 AM
bogleparsons
So true, everything I read and looked up said my driveshaft should have been something like 15 1/2" but it ended up being 12 "
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #11 of 11 Old 01-23-2013, 06:23 AM
gunshw301
Can't imagine one just breaking. I would think something locked up that caused this to break in the first place.
I have a shaft from my 2.5l 5 speed if it will help, I am on my phone so I can't seem to look up your jeeps specs.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
