where can i get a replacement brake line (not the brake hose) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > where can i get a replacement brake line (not the brake hose)
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 06-04-2005, 06:03 PM   #1
cueball
i tried to disconnect the preformed brake line that runs from the master cylinder manifold to the rubber brake line on the drivers side front.. i ended up rounding off the hex head and rendered it useless.
where can i get just that part? i dont want to shell out the bucks for the entire set and want to just replace this one.
i also thought about cutting the stripped piece off and replace it and flare out the line again. wouldnt lose that much of my brake hose since i am putting on extended braided hoses. but if i go this route, how do i cut the thing cleanly?
Bye to the old - 1988 6 cyl 5 speed with a 94 rollbar, tomken 2x4 rocker skids and homebrewed OBA.
Hello to the New - 1999 TJ Sport 4.0L auto.. stock for now
cueball is offline   Reply With Quote
Unread 06-04-2005, 06:49 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Go to NAPA.. I believe they sell 3/16" line in 12", 20", 30" and 40" lengths. You can piece a couple together if needed. Cheap too.. like $4 each.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 06-04-2005, 06:55 PM   #3
ozzysjeep
steel lines
We just replaced two steel brake lines today and what a PITA. Found everything we needed at Sanels and Robbins but not at VIP or Autozone. You have to go where the repair shops get their parts.
[COLOR="White"]OZZYSJEEP
Live Free or Die
[url]www.neow.net[/url][/COLOR]
ozzysjeep is offline   Reply With Quote
Unread 06-04-2005, 09:00 PM   #4
Mr. Notorious
The dealership had the line running to the rear, prebent for only like $17. For the front, I used and angle grinder with a cut off wheel then re-flared them. Napa had the flair nuts for cheap.
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE
1967 FJ, linked, 350 chevy, 35's, arbs, blah blah...
2002 TJ
"If you're not moving ahead, you're falling behind"
Mr. Notorious is offline   Reply With Quote
Unread 06-05-2005, 12:49 AM   #5
TellyDSP
Poland and PPV!!!!
I stripped my fitting for my passenger side hardline whe doing my lift. Wound up cutting the fitting off and replaceing with a new one. Flared the line and everything is good. Just get a new fitting and flare it. Picked my fitting up at advance auto, or salvo or something.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Unread 06-05-2005, 06:19 AM   #6
TSEJEEPERS
To cut the line use a tubing cutter like you use to cut copper pipe. Any hardware store will have these and flaring tools in stock. The correct way is to cut it and flare it but alot of auto parts stores carry compression fittings that will work too. I have seen these used and yes they did work. I personally have never used them though. In the future when taking break lines off use a line wrench and either liquid wrench or some heat!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Unread 06-05-2005, 06:42 AM   #7
cueball
for the $4.00 for the brake line and $5.00 for a bending tool, i think i will just go that route..
thanks everyone.
