where to buy the gas tank cap that seals the pump in the tank? - JeepForum.com
post #1 of 9 Old 04-16-2010, 05:48 PM Thread Starter
kmd1776
hey everyone, im helping out my neighbor on his 91 yj. we need to change the fuel pump, but unfortunately the whole top mounting plate that bolts to the gas tank has rusted out and we have no idea where to get a new one. went to multiple auto parts stores and no one can locate this part. does it exist out there???
04 wj limited; 4.7L V8, 247> 242hd swap; Hayden auxillary tranny cooler; BFG All Terrain 245/70/17; Moog Up-Country Coil Springs; Monroe Reflex Monotube Shocks; JKS BPE's; Chrome Overland tow hooks; Dynomax Ultraflow catback
kmd1776 is offline
post #2 of 9 Old 04-16-2010, 05:53 PM
Mark05059
you need the fuel pump "hanger" Sometimes you can get it all in one piece. If you let us know what engine size you have we can help you further.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 9 Old 04-16-2010, 05:58 PM
xdgt03
the cap comes attached to the the pump assembly. The rubber gasket underneath will probably need to be replaced if he didn't get that. Did he just buy the pump? That will not work if the plate is all rusted out. He will need the full assembly.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #4 of 9 Old 04-16-2010, 06:07 PM Thread Starter
kmd1776
he has the 4.0L. so far ive seen both the carter and spectra fuel pumps and neither of them offer the whole setup, at least what i can find...any other brands out there that im missing?
kmd1776 is offline
post #5 of 9 Old 04-16-2010, 06:20 PM
Burnerman
Burnerman's Avatar
You need to buy the sending unit. It's the whole piece that mounts in the tank. They can be bought with or without the pump. You can find them cheaper but here's one...PartsTrain.com - Hard to Find Auto Parts and Truck Parts -
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #6 of 9 Old 04-16-2010, 07:38 PM
xdgt03
He needs this
$169 from
JEEP WRANGLER YJ NEW FUEL SENDING UNIT & PUMP 1991 1992 : eBay Motors (item 360242140585 end time May-08-10 15:29:22 PDT)
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #7 of 9 Old 04-16-2010, 08:18 PM Thread Starter
kmd1776
yes thats exactly what i need.... does anyone know any brands that make these fuel sending units?
kmd1776 is offline
post #8 of 9 Old 04-17-2010, 07:18 AM Thread Starter
kmd1776
ok guys after doing some research, i see the 94-95 fuel pump/fuel sending unit is readily available everywhere for a reasonable price. does anyone know what the difference is between the 91-93 sending units and the 94-95 sending units?? is it fairly easy to convert a 91-93 unit to the newer 94-95 setup??
kmd1776 is offline
post #9 of 9 Old 04-17-2010, 11:26 AM
xdgt03
I'm guessing that it is a matter of pump pressure. I don't know for sure. That would mean that they are not interchangeable. I ordered mine off ebay because it was way cheaper that anything local (over $200). I also painted the plate and tubes before I installed it to help forestall any future rust issues.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
took the gas tank down today . need the rubber seals somar YJ Wrangler Technical Forum 31 06-15-2009 11:23 AM
Why put the fuel pump in the gas tank? Deserthiker YJ Wrangler Technical Forum 10 01-30-2009 07:19 AM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 06:13 PM
Air pump & tank or CO2? Gunnison TJ Wrangler Technical Forum 13 11-01-2007 07:44 PM
Gas tank/Fuel pump bbunn1 YJ Wrangler Technical Forum 8 07-23-2004 08:45 PM
