When to lift during a ground up rebuild? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > When to lift during a ground up rebuild?
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 03-26-2013, 06:35 AM   #1
shink
I'm working on a complete rebuild of a 90 YJ. The tub has just come off and work on the guts is abount to begin. While looking it I was thinking that putting a suspension lift on it will be easier before I put the body back on. Good idea or no? Do I need the weight of the body on the frame at the time of the lift? Thougts?
Assume I know nothing. Because I don't.
shink is offline   Reply With Quote Quick reply to this message
Unread 03-26-2013, 07:03 AM   #2
SCRMBLD
I'd put the new springs, steering, brakes, motor mounts, fuel lines & etc on now. Just buy new shocks until you have the body on and know the suspension travel.
ΜΟΛΩΝ ΛΑΒΕ
SCRMBLD is offline   Reply With Quote Quick reply to this message
Unread 03-26-2013, 08:17 AM   #3
jsawduste
2006 YJ Wrangler
You can install the lift now. Just don`t tighten the u bolts because you will want the full sprung weight on the axles to set the pinion angles.
jsawduste is offline   Reply With Quote Quick reply to this message
