when I use my 4x4 - Page 2 - JeepForum.com
post #16 of 31 Old 02-02-2014, 11:16 PM
imstillatwork
Well we can't tell by his profile info, but by his description, he's got a 2.5l. I know how it goes. That's why mines sitting on the garage floor right now.
imstillatwork is offline
post #17 of 31 Old 02-03-2014, 02:46 PM
jeepguy85
1987 YJ Wrangler
Originally Posted by jsawduste View Post
In your case I would avoid using the 4wd.
Problem solved.
Now that is hilarious!
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #18 of 31 Old 02-03-2014, 02:49 PM
jeepguy85
1987 YJ Wrangler
Can anyone tell me why when I am driving at night and roll my manual crank windows down my headlights turn out??????
post #19 of 31 Old 02-03-2014, 03:21 PM
ionakana
Grand Poobah
ionakana's Avatar
Could also be a clogged cat if it has to cool off before it will run again.
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #20 of 31 Old 02-03-2014, 04:44 PM
NHfireLJ
NHfireLJ's Avatar
Right MEOW?
SOLD
YJOTM FEB 2013
NHfireLJ is online now
post #21 of 31 Old 02-03-2014, 05:35 PM
Firefyter-Emt
Worn piston return springs maybe?
Firefyter-Emt is offline
post #22 of 31 Old 02-04-2014, 03:29 PM
jeepdog5
jeepdog5's Avatar
good lord this thread was a waste of my life
jeepdog5 is offline
post #23 of 31 Old 02-04-2014, 03:41 PM
rd94yj
Originally Posted by acooper984
My 1995 jeep wrangler it bogs down and then it starts boging down and then it stops running and then I can't get it stated back up I have to let it sit for a while until I get it started again
Don't know why everyone is messing around.
It would most likely be one or two different things. Either you have two different gear ratios in the front and rear axles. Or your transfer case shifter linkage isn't allowing you to shift into 4 lo and you think your 4lo when your actually in 4hi.
Since your still on the OBD1 system you should check your codes to see what shows up. Sounds like your engine may have some other issues related or unrelated to the 4wd problem.
But your post doesn't make much sense and you didn't provide us with good information.
Teach yourself about your jeep and provide us more info. Such as engine size, trans type, transfer case type. What your trying to do and what is happening.
Good luck.
94 YJ 60/14 bolt 4.0 ax15 Dana 300
88 YJ 60/14 bolt AMC 360 nv4500 np241
rd94yj is offline
post #24 of 31 Old 02-04-2014, 05:03 PM
jsawduste
2006 YJ Wrangler
Your fat assed hands hit the HL switch ?
jsawduste is offline
post #25 of 31 Old 02-05-2014, 09:50 AM
jeepguy85
1987 YJ Wrangler
Hey! They are working on losing the weight! They are pleasantly plump, but not fat. LOL
post #26 of 31 Old 02-05-2014, 07:55 PM
Jeffro06
Jeffro06's Avatar
The OP has never been back, I don't think he cares.
Jeffro06 is offline
post #27 of 31 Old 02-05-2014, 08:02 PM
jsawduste
2006 YJ Wrangler
Originally Posted by Jeffro06 View Post
The OP has never been back, I don't think it cares.
Fixed it for you.
post #28 of 31 Old 02-05-2014, 08:21 PM
Jeffro06
Jeffro06's Avatar
Fixed it for you.
Spambot?
Jeffro06 is offline
post #29 of 31 Old 02-05-2014, 09:33 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
This thread is a little off topic. Let's get back on track or go somewhere else.
Luck Favours The Prepared
Anticanman is offline
post #30 of 31 Old 02-05-2014, 10:03 PM
jsawduste
2006 YJ Wrangler
Vote to go somewhere else.
