when I use my 4x4 - JeepForum.com
post #1 of 31 Old 02-01-2014, 06:32 PM Thread Starter
acooper984
when I use my 4x4
My 1995 jeep wrangler it bogs down and then it starts boging down and then it stops running and then I can't get it stated back up I have to let it sit for a while until I get it started again
acooper984 is offline
post #2 of 31 Old 02-01-2014, 07:11 PM
jsawduste
2006 YJ Wrangler
In your case I would avoid using the 4wd.
Problem solved.
jsawduste is offline
post #3 of 31 Old 02-01-2014, 07:17 PM
Dake
Dake's Avatar
You probably a vacuum leak in the 4x4 system. Its most likely between the switch on the TC and the font axle.
Waiting on my Rough Country lift to sag!
Dake is offline
post #4 of 31 Old 02-01-2014, 09:19 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Problem solved.
On a roll tonite, huh?
As Dake said, start looking into a vacuum leak going to your front axle.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #5 of 31 Old 02-01-2014, 09:24 PM
Jeffro06
Jeffro06's Avatar
What are you doing when it starts to bog? 4wd can't work miracles, if you're in the wrong gear or don't have the gearing needed for the conditions you're driving in it will bog.
Jeffro06 is offline
post #6 of 31 Old 02-01-2014, 09:31 PM
jsawduste
2006 YJ Wrangler
Some days you just feel like being a dick.
The OP has been a member for a year now. I`ve read and re read his question and have come to the conclusion that he is totally lost and cannot even convey his problem adequately.
Hoping that a bit of sarcasm might motivate him to try just a little harder.
post #7 of 31 Old 02-01-2014, 09:41 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Roger that. I spent a half hour today reading thru SOA help that you offered and am aware of what you are capable of. Carry on, Sir.
YJOTM JULY 2014
DirtKar is offline
post #8 of 31 Old 02-01-2014, 09:44 PM
jsawduste
2006 YJ Wrangler
Thanks Larry
post #9 of 31 Old 02-01-2014, 09:44 PM
WNUNEZJR
You sure your not just stuck in some mud or some thing??
WNUNEZJR is offline
post #10 of 31 Old 02-02-2014, 11:59 AM
jred
Not sure about the needing to sit before it'll start back up again, but the other day we were riding with someone who didn't have a lot of experience. She kept bogging down & stalling out. 3/4 of the way through, someone hopped in her jeep to help her through a rough spot. Turns out she'd been in 4hi the whole time, once she dropped to 4lo, she stopped bogging down and stalling.
Some times it's the simple things...
jred is offline
post #11 of 31 Old 02-02-2014, 12:06 PM
NHfireLJ
NHfireLJ's Avatar
REALLY? From a guy who was asking about using a RC lift even though he was told it SUCKS....
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #12 of 31 Old 02-02-2014, 04:38 PM
WNUNEZJR
I was young naive and broke well I still am broke.
WNUNEZJR is offline
post #13 of 31 Old 02-02-2014, 05:07 PM
jsawduste
2006 YJ Wrangler
No excuse and things have not changed. I don't call 18 to be "seasoned".
post #14 of 31 Old 02-02-2014, 06:47 PM
Michaelgoesrawr
Help us help you bud. We can't understand what the hell you're trying to say.
Michaelgoesrawr is offline
post #15 of 31 Old 02-02-2014, 10:11 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Due to a horrible description I will just say your fuel pump is overheating and reducing pressure thus bogging down and shutting off .
Or your in 4hi and in the wrong gear when you should be in 4lo Your possibly under geared for your tires. Maybe a combination of all the above.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
